Old 02-11-2006, 07:58 AM   #1
XMSRacing's Avatar
Send a message via AIM to XMSRacing Send a message via Yahoo to XMSRacing
Default Stock Motor Bushings...
I'm trying to figure out what I can use to polish/hone the bushings in stock motors. I was hoping to find something to use with my dremel to speed up the process, so I sat at Home Depot looking at Dremel accessories for about 15 minutes trying to find something, with no luck.
Any tips/ideas?
XMSRacing is offline   Reply With Quote
Old 02-11-2006, 08:25 AM   #2
Use a Q-tip as the tool, thread the stick end through the bushing and pull the cotton fuzz into place. It doesn't take too long, so low speed on the dremel for a couple minutes or so is all I usually do.
Some people use toothpaste, not the gel kind, but like the old Crest paste. It has just enough fine abrasives in it, and it's easy to clean up. I use Mother's mag wheel polish I had laying around.
I also take the bushings out and use 2000 grit sandpaper on the face of the bushing where the shims ride. The face isn't usually too smooth to start.
Hope this helps.
JC
Bike racer is offline   Reply With Quote
Old 02-11-2006, 08:28 AM   #3
AM03GT's Avatar
use dremel to spin an old armature in the can, and the enbell with some toothpaste or polishing compound...
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 02-11-2006, 09:01 AM   #4
XMSRacing's Avatar
Thanks for the ideas guys!
I dont think I'm going to remove the bushings from the endbell and can though... I would be concerned about seating them again so that they are perfectly alligned.
Old 02-11-2006, 12:06 PM   #5
stuey's Avatar
Any tips/ideas?
hey
The easiest way to get your stock motor bushing spot on in seconds is to use a 1/8th straight reamer, I tend to take the arm out of the motor and put the end bell and can back together and twist the reamer back and forth through both bushings. then reabuild the motor with a touch of oil the shafts job done.
stuey is offline   Reply With Quote
Old 02-11-2006, 12:31 PM   #6
MrUnlimited's Avatar
Any tips/ideas?
If the stockmotor is type with a closed endbell you could use silver of copper polish by putting some drops on the shaft near the bushing. Twist the armature a few times in side the can. After that you can put the shaft (where the pinions is attached) in a drill and spin it for a few minutes on low speed. Once done spray the bushing out with a decent motorcleaner and oil them with a quality oil.
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Stock motor Bushings!! baw888 Australia Wanted to Buy 0 04-01-2008 04:31 PM
Swap Motor Bushings for Bearings Jake S Electric On-Road 12 03-21-2007 11:28 PM
NEEDED: Some Stock Rustler Bushings oMONSTERo R/C Items: Wanted to Buy 3 09-11-2006 09:36 PM
Removing Motor Bushings? micros_rock Electric On-Road 7 08-09-2004 12:53 AM
Pressing bushings back into stock motor Still Bill Electric On-Road 4 07-10-2004 11:03 PM
