Xpress Execute XQ1S Sport Clubracer >
Like Tree422Likes
Old 05-11-2018, 11:37 PM
  #61
Originally Posted by WagwanBumba View Post
I tried using an m3 tap on this kit - I'd never go full way through as it does really loosen the mechanical grip when tapping plastics. My preference would be to bore out the plastic hole with a 2.8mm drill bit as it opens up the hole a bit so that it makes it a bit easier to screw in to the plastic but leaves enough for the screw to have a good bite on it.
Correct me if i'm wrong, but I suspect you were using a normal thread cutting tap. Thread forming taps don't remove any plastic (or metal!) and lead to much deeper thread depths. The Tamiya tap is about $10, and others can be found on the market. The Tamiya one doesn't have a lubrication groove... so there's that.
Using a thread forming tap leads to much stronger threads than thread cutting, and I've not wanted a power screwdriver to install any screws on cars that I've used a thread forming tap on.
Nerobro is offline
Old 05-13-2018, 06:07 AM
  #62
What Spur gears are compatible with this chassis?
JohnRollesten is offline
Old 05-13-2018, 08:26 AM
  #63
Did not know about forming taps! Will have to check those out
WagwanBumba is offline
Old 05-13-2018, 08:28 AM
  #64
Axon, Panaracer, Leespeed .... basically anything. The spur is held in place with screws so spur gear thickness around the pulley area isn't a problem.
Old 05-13-2018, 04:58 PM
  #65
gigaplex's Avatar
Pretty much any spur with the 3 hole pattern. Which is most, since most modern cars rely on that.
gigaplex is offline
Old 05-13-2018, 11:04 PM
  #66
Professor's Avatar
Default Spur
Leespeed & Panaracer will fit
Professor is offline
Old 05-14-2018, 08:07 PM
  #67
Would a 63 Spur fit or you think that would be too small?!
Old 05-14-2018, 11:18 PM
  #68
Regional Moderator
disaster999's Avatar
Are you planning on running a 1:1 gear ratio? You would need a pretty big pinion to run that spur or the motor won't move back enough
disaster999 is offline
Old 05-14-2018, 11:58 PM
  #69
Planning to run 21.5 with an r1 v16 and i need a spur to get ratios around 3.50
Also is this chassis compatible with XQ1 parts like roll bars and drive shafts?
I saw a normal XQ1 destroy Xray t4's and current model yokomos very interested to give the cheaper variant chassis a go and upgrade it if i like it.
Old 05-15-2018, 01:13 AM
  #70
Regional Moderator
I run 3.7 FDR with a 102 spur and 52 pin....not sure what your planning on doing with a 63spur....wait, is that 48pitch you're talking about?
Old 05-15-2018, 01:15 AM
  #71
Correct i am talking about 48 pitch spur
Old 05-15-2018, 01:18 AM
  #72
gigaplex's Avatar
You probably want something around 68-70T for 48P
gigaplex is offline
Old 05-15-2018, 01:20 AM
  #73
Thanks very much mate i got pinions ranging from 33-40 so ill likely have the right ratio via that.
Old 05-16-2018, 12:59 AM
  #74
I runa 63T or 64T spur with 33T - 37T pinion in my TA07 in 21.5T blinky so you're on the money with your range. I'm looking at this chassis to replace the TA07 for indoors, I love Tamiya but the upgrades will cost too much to make it competitive
jgil089 is offline
Old 05-16-2018, 01:16 AM
  #75
You'll be extremely happy with the car! I just put this car on the track this weekend running 13.5T blinky and added ARBs from an old BD7 (1.2mm front and rear) with the car completely stock/kit otherwise (springs, shock oil, diff oil) and it was a gem to drive. Will try tweak the springs next week but it was a delight to drive and was game straight away!
DaSilva3525 and jgil089 like this.
