Xpress Execute XQ1S Sport Clubracer >
Like Tree469Likes
Old 11-30-2020, 11:48 AM
  #676
I reset the car using one of the asphalt setup sheets from Marcos J and the car drives excellent with lots of traction and steering! I'll see how it does next race on Dec 20th. It is absolutely more controllable and easier to drive now.
Marcos.J likes this.
Xrayray is offline
Old 12-02-2020, 07:41 AM
  #677
This will be my first On-road build. Anything I need to pay attention to during the build? What is recommended/needed for option parts?
Anyone have a good setup for a medium grip carpet track?
Thanks in advance 😊🙏
Tigergutt is offline
Old 12-02-2020, 07:46 AM
  #678
look out on shock build east to cross thread the shock bodies when screwing on alloy bits it’s ok just pay 100% attention to them lol upgrades it’s fine out the box just get anti roll bars
u could put the xq1 shocks on and hinge pin holders for more adjustments if you want
there is the mid motor kit for it but if you only just got it run it first it’s mega bang for buck out the box
also If you fitting alloy chassis (if you go to high grip carpet ) u will need xq1 motor mount and lay shaft holders
r_lud is offline
Old 12-02-2020, 02:17 PM
  #679
gigaplex's Avatar
Alloy wheel hex. They do nothing for performance but after you've dropped the cross pin for the 100th time while changing tyres, you'll wish you had.
Xrayray and r_lud like this.
gigaplex is offline
Old 12-03-2020, 07:28 AM
  #680
Thank you for your replies 🙏
r_lud likes this.
Old 12-03-2020, 10:18 PM
  #681
Make sure all the suspension falls free. That way the sway bars will work perfectly. Check the sway bars on glass and measure the endlinks well. Get the AL steering posts and extra shims. Check that the rear belt is not as tight as the front. Grease up the turnbuckles, droop screws, and the top deck screws with Chapstick or similar. Use a 5mm or 6mm ballstud on the lower arms instead of the 8mm setscrew.
Xrayray is offline
Old 12-05-2020, 11:03 PM
  #682
Here's what I came up with. This is on a dusty parking lot track. No spray.
File Type: pdf
Xrayray is offline
Old 12-28-2020, 12:15 PM
  #683
Tractagator's Avatar
Originally Posted by ASM View Post
If you need anything else please let me know. I'm in-process of trying a completely different set-up and now have the mid-motor set-up, with more changes to come but I'll help you get to where you need to be. Plus Felix Law is down that way and he'll be glad to help any fellow Xpress racers too.
Your setup was on point this Sunday! Thanks again!
ASM and moparSRT like this.
Tractagator is offline
Old 01-11-2021, 05:26 AM
  #684
https://www.redrc.net/2021/01/xpress...s/#more-196977
Old 01-11-2021, 08:04 AM
  #685
ASM
ASM's Avatar
Trader Rating: 26 (100%+)
Glad it helped to give you a baseline. Latest - and hoping to get it on track soon.
Marcos.J, Tractagator and Mitamiya like this.
ASM is offline
Old 01-13-2021, 01:36 PM
  #686
Look in bottom right corner possible option to make ur xq1s to a fwd and if anything like xq1s mid kit should be cheapish
r_lud is offline
