Xpress Execute XQ1S Sport Clubracer >
Like Tree225Likes
Old 10-09-2018, 02:02 PM
  #301
Tech Legend
Marcos.J's Avatar
Trader Rating: 199 (100%+)
Originally Posted by Tractagator View Post
Made a brass fan mount for my sons car. He was shy on weight, heavy on the battery side, and I dont trust his driving enough to put faith in serve tape holding down the fan in the event that a barrier jumps out and smacks his car....lol
loop
looks pretty cool but I would try to move the fan about 10mm away from the motor the magnetic field from the rotor will slow the fan down
Tractagator likes this.
Marcos.J is offline
Old 10-09-2018, 02:26 PM
  #302
Tractagator's Avatar
That can be done, thanks.
Tractagator is offline
Old 10-09-2018, 03:47 PM
  #303
gigaplex's Avatar
Originally Posted by Marcos.J View Post
Yokomo and yes they do also putting the axle spacer in Between the axle bearings helps a lot
Which axle spacer do you use? There's a lot of slop around the bearings.
JC3 likes this.
gigaplex is offline
Old 10-09-2018, 05:18 PM
  #304
Tech Legend
Marcos.J's Avatar
I used these in between the bearings they are a Schumacher part number U2153
Marcos.J is offline
Old 10-09-2018, 05:30 PM
  #305
Tech Legend
Marcos.J's Avatar
Spacers and Pins - pin drive - SST (4 sets) # U2153 from Schumacher RC Racing.
Marcos.J is offline
Old 10-09-2018, 05:43 PM
  #306
JC3
JC3's Avatar
These might work....
Marcos.J likes this.
JC3 is offline
Old 10-09-2018, 05:46 PM
  #307
Tech Legend
Marcos.J's Avatar
prety sure they are the same size , i just happened to have extra Schumacher parts from previous kits
Marcos.J is offline
Old 10-09-2018, 07:19 PM
  #308
gigaplex's Avatar
What's their thickness? I've got some spare plastic ones from my M07 that might work, though they're about 1.5mm thick and I'd estimate they need to be closer to 2mm thick.
gigaplex is offline
Old 10-10-2018, 03:40 AM
  #309
Tech Legend
Marcos.J's Avatar
1.5mm
gigaplex likes this.
Marcos.J is offline
Old 10-10-2018, 05:18 PM
  #310
Ain't done right if it ain't done twice...
Old 10-10-2018, 06:14 PM
  #311
foampervert's Avatar
Default i wonder...
Thanks for sharing a beautifully machined piece of kit! I've always wondered if people setup their fans as pushers or pullers? if it's a puller, the gap between the fan and motor makes it less effective? as a pusher, the fan is working against underbody air movement, and may still be ineffective?
Wouldn't a fan on an attached heatsink be best? energy transfers to the heatsink which is then cooled by the fan (which is attached to the heatsink)?
foampervert is offline
Old 10-10-2018, 06:25 PM
  #312
Directed airflow is best. EG: pusher. You can't direct "pulled" air, so you're pulling from all directions. Heatsinks are big, and heavy. "some" airflow goes a really long ways. Ducts are best... But not many people run ductwork.
It's also important to to have some kind of duct on even an "open" fan. Fan air reingestion is amazingly effective at re-ingesting hot air.
Nerobro is offline
Old 10-12-2018, 04:30 PM
  #313
Default So...
Hmmm, that kinda means that the 3d printed ducting you see a lot works much better then an open fan in Pusher configuration, even if it's against natural airflow? What about a ducted puller fan? The fan won't be working against airflow, and won't be recirculating heated air either, right?
Old 10-12-2018, 10:23 PM
  #314
There's not so much "flow" under the body of a r/c car. *shrugs* grab a thermocouple, do testing. :-)
Nerobro is offline
