Old 11-28-2002, 07:46 PM   #1
Default Resistor question
What watt resistor will I need for a 1.7 volt, 20mA led. There are 4 of these in a series circuit off a 9 volt battery. I know that I will need a 110ohm resistor, but found out there are 3 different types of watts: 1watt, 1/2watt, and 1/4watt. Which watt resistor will I need in my situation?
racinZrooky is offline   Reply With Quote
Old 11-28-2002, 08:05 PM   #2
Send a message via AIM to zads
Power = (Current^2)*(Resistance)
So you'll only have 0.044 Watts goin through.
You want the rating to be much more than the calculated values for the components, but in this case, the 1/4W resistor is still plenty. (5.6x the calculated rating)
zads is offline   Reply With Quote
Old 11-29-2002, 03:05 PM   #3
Thank you zads!
AMB Personal Transponder, Does it need Resistor? LOSI123 Electric On-Road 3 03-16-2007 06:00 PM
Resistor type discharger with auto cut-off device, How do you make it? Marc_05 Australian Racing 49 07-17-2005 03:29 AM
Smoked Pro-max Activator - Resistor Burned? waterblast02 Electric On-Road 0 12-21-2004 09:10 PM
Resistor type discharger marc Electric On-Road 7 03-09-2003 02:27 AM
Resistor question racinZrooky Electric On-Road 3 12-08-2002 08:23 AM
