Old 02-10-2006, 03:54 AM   #1
Default LiPo Charger question
What do you look for when buying a Lipo charger?
Can anyone recommend one? i dont need another do it all expensive charger. Probably something under $60.
chumanji is offline   Reply With Quote
Old 02-10-2006, 05:05 AM   #2
hobbipro's Avatar
Trader Rating: 21 (100%+)
If your going to be charging the orion/peak platinums 4800's, look for a li-po charger that will go up to 5 amps, 4.8 is the recommended setting for those. Atleast for the orion/peak nothing else is really required as long as it is made for charging li-po's, not really sure about other batteries springing up these days. I think integy is making some li-poly only chargers now under $100, and FMA makes some inexpensive ones also, than the scorpion.
hobbipro is offline   Reply With Quote
Old 02-10-2006, 05:07 AM   #3
hobbipro's Avatar
http://www2.towerhobbies.com/cgi-bin...?&I=LXLWF0&P=7
Old 02-12-2006, 01:24 PM   #4
How are these two chargers?
From Hobbyshack
http://www.hobbypeople.net/gallery/158374.asp
And Tower
http://www2.towerhobbies.com/cgi-bin...?&I=LXKSY1&P=7
Old 02-12-2006, 05:36 PM   #5
hobbipro's Avatar
The specs on both chargers look identical, just one has bananna jacks on the side instead of the top. Cant go wrong with either IMO.
Old 02-12-2006, 11:22 PM   #6
Xcal's Avatar
Send a message via ICQ to Xcal Send a message via AIM to Xcal Send a message via MSN to Xcal
The Duratrax ICE charges LiPo batteries too but is a bit more expensive than $60. There has been a fair bit of discussion about it lately in its thread if you find it you can read more about it.
Xcal is offline   Reply With Quote
Old 02-12-2006, 11:43 PM   #7
XrayFK's Avatar
I don't get it, you will buy a $140 battery pack, but then cheap out on the charger? Doesn't make sense to me.
XrayFK is offline   Reply With Quote
Old 02-13-2006, 04:16 AM   #8
hobbipro's Avatar
Maybe he already has one, for NiCad/Nimah. Or If all he's going to run is li-po why would you need all those extra features? I have a 16x8v6 with built in dyno, and now asking myself the same thing after spending $229........
Old 02-13-2006, 02:11 PM   #9
Hobbipro got it right on the money. I already got a do it all charger (eagle racing cdc) that charges Nicd/Nimh with 20A discharger/cycler build in. So I just want a Lipo only charger for my Mini LST's lipo packs.
Old 02-13-2006, 02:39 PM   #10
kuzo's Avatar
Send a message via MSN to kuzo
This is what I picked up for the Orion Plats:
Integy 16x Lithium
It's cheap and incredibly small. If you don;t need the power supply they sell a version without it. I'm already running a 16x7 for my GPs which I'm happy with and I didn't see a reason to drop that much more money when I didn't have to. Just got the batteries in today so I'll see how well it works soon.
kuzo is offline   Reply With Quote
Old 02-13-2006, 07:30 PM   #11
Talking chargers
16 Posts Since Jun 2005 02-10-2006, 10:54 AM LiPo Charger question Report | Post #1
use a model aircraft type if it is for fun. if it is competitive racing then the orion charger maybe but it will be more than $60
atomicandy is offline   Reply With Quote
Old 02-14-2006, 01:18 AM   #12
pookat's Avatar
One that charges Lipo's probably Andy
pookat is offline   Reply With Quote
Old 02-14-2006, 09:07 AM   #13
yes i am aware of that merv i was just answering chumanjis quetion
Old 02-14-2006, 10:22 AM   #14
tboned_2002's Avatar
if you just want to charge LiPos then get the Astro Flight charger, its about 120, it will only charge LiPos, however this is the best charger as it will charge the battery to its fullest capacity as the other ones posted will not.
http://www.astroflight.com/e/env/000...roducts:af-109
tboned_2002 is offline   Reply With Quote
LiPo: Charger and Battery Question Czolgosz Electric Off-Road 18 10-30-2008 09:09 PM
Lipo Charger question Kevin K Electric On-Road 30 10-05-2008 05:55 AM
tt01/lipo/esc/charger/question FortySix Singapore R/C Racers 0 05-01-2008 07:03 AM
oh no! another lipo charger question jedsled Radio and Electronics 2 03-08-2008 06:42 PM
Lipo charger/pack question!! n3rd420 Rookie Zone 0 05-22-2006 12:39 PM
