Like Tree698Likes
Handout motors
Old 03-27-2018, 02:34 PM
  #286
NutDriver's Avatar
Trader Rating: 26 (100%+)
Looks like Gigaplex and I were typing at the same time.
gigaplex likes this.
NutDriver is offline
  #287
DARKSIDE's Avatar
Originally Posted by miller tyme View Post
OH boy this one is going to blow up
Which classes need it the worst?
none
How can the motor manufactures still showcase their product?
if needed bid on the event
Cheap fixed/sealed motor or standard motors all set the same?
standard per event with same timing
Does a specific wind matter or a unspecified motor labeled as "stock"? (similar to 360v2.
no, just for that class
I will try not to comment, I want to hear other opinions
let the fun commence
simple
DARKSIDE is offline
Old 03-27-2018, 02:37 PM
  #288
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
1) racers $$ decisions are the only thing to change the builders practices, or the governing body dropping the axe
2) more than the buying habits, the conversations, lets say he who screams the loudest....
3) YES, but some of the original questions have been brushed aside.
I think a handout/control/spec motor at BIG RACES is the proverbial writing on he wall, and the manufactures who complain about it are the ones to blame.
The real questions is method used a sealed motor possible luck of the draw similar to the old brushed days, or a tested, adjusted, then sealed motor. with cost and future usability being the side-affect
Speak the truth Ken
This summer we will cook up something to save on-road!!
miller tyme likes this.
hanulec is offline
Old 03-27-2018, 02:39 PM
  #289
NutDriver's Avatar
Heading in a different direction, what about handout tires in VTA? When you come to tech to get your voltage and weight checked, you get a set of tires to mount for that heat. When you finish your heat and go to marshal, a tech person takes the handout tires off of your car. You can't touch them aside from mounting them to your car. Want a 25.5 with an 84mohm resistance? Have fun. A set of premounts that you take home to do with what you want seems cheaper and less protestable than motors. Just an idea.
  #290
mleemor60's Avatar
That is simple. Rules say no adjustment or the user of the motor must converse with the owner prior to changing anything. A few dabs of thick water based paint on the screws and go for it. This idea isn't a cure but a vaccination to make the illness a little milder until the Asian "swine" flu can be cured. Something workable until the anti purchase boycott takes a toll. The only ones hurt by this type of action are the willy wannabe's. The racers will dig in and deal with it.
I like the tire idea as well.
NutDriver likes this.
mleemor60 is offline
Old 03-27-2018, 02:45 PM
  #291
DARKSIDE's Avatar
in the "old days"...why yall quit using handout motors?.....and why are guys/racers seeing all of this and still continue to buy motors at $150?.... and why is RD at motor companies still looking for the better mouse trap?.... why is entry count still up and growing at events that still charge $100 an entry?....WHY?
Im only asking cause I honestly dont see the issue. I could see an issue if say the USIC had 70 17.5 TC cars last year, and turn out 20 this year?....that gets my attention. But thats not the case....entry count went up in 2017 compared to 2016...and not just there,as well as other events too....maybe its just me?....
but Im all in no matter what is done...I refuse to go back to trains and slots
Antimullet and NutDriver like this.
DARKSIDE is offline
Old 03-27-2018, 02:46 PM
  #292
scirocco14's Avatar
Like every other 'equalization' process that has been tried in racing for eons, it always sounds good in principle. Then gets slaughtered by the devil in the details.
Just spec a motor that is just SLIGHTLY too much motor for the chassis/tire combo and have at it. Problem goes away.
In full scale racing, I used to see guys spend $10-15K on a 60hp, 1600cc VW aircooled motor built to very tight specs. There, 1 or 2 hp was a big deal and made the difference. Formula Vee ends up being a very expensive class to run at the top levels.
Or you could spend that motor on a 358 cu in small block V8 and put it in a chassis with narrow slicks. All of a sudden, there's no need for that extra 1 or 2 or 25 hp. Can't use it.
Which class do you think is cheaper to run?
Mark C
mleemor60, dave-man and Antimullet like this.
scirocco14 is offline
Old 03-27-2018, 02:50 PM
  #293
DARKSIDE's Avatar
bring back BOOSTED.....HELL YEAH!!!...come on Tekin you been waiting on this one
el salvador likes this.
DARKSIDE is offline
  #294
DARKSIDE's Avatar
except VTA, dont touch my class
DARKSIDE is offline
Old 03-27-2018, 02:57 PM
  #295
gigaplex's Avatar
How do you police the overgearing concern? How do you stop people from detuning their motors and saying no when someone asks to adjust it? Too many loopholes.
gigaplex is online now
Old 03-27-2018, 03:21 PM
  #296
DesertRat's Avatar
Super Stock should have always been BOOSTED. I had to take a few minutes once to show a younger guy what boost was, he didn't realize it was as significant as it is in increasing your top end power.
Maybe I'm biased because my boosted setup was brutal fast. But I still have it in my box, ready to roll in anger again.
How about this: 17.5 Stock, 17.5 BOOSTED Super Stock, Open Mod.
Re-programming my ESC didn't cost $150, that is for sure.
DesertRat is offline
Old 03-27-2018, 03:45 PM
  #297
DARKSIDE's Avatar
Mod TC, open esc and motor
17.5 TC, open esc and ROAR motor
thats 2 TC classes
USGT, open esc and 21.5 ROAR motor
USVTA, blinky esc and 25.5 ROAR motor
thats 2 scale classes
that gives us just 4 classes with touring car chassis, just a thought
and pan car
Mod 12th, open esc and motor
13.5 12th, open esc and 13.5 ROAR motor
pure 12th scale
WGTR, open esc and 17.5 ROAR motor
Formula 1, blinky esc and 25.5/21.5 ROAR motors
2 scale pan classes
DARKSIDE is offline
Old 03-27-2018, 03:49 PM
  #298
jlfx car audio's Avatar
Trader Rating: 37 (100%+)
Entry count going up cause " TRUMP "
He isnt perfect ... But folks are spending more money and going places ... Its economy not 17.5 cheater motors bringing racers to the track .
DARKSIDE likes this.
jlfx car audio is offline
Old 03-27-2018, 03:51 PM
  #299
nrtv20's Avatar
thats 2 TC classes
USGT, open esc and ROAR motor
USVTA, blinky esc and ROAR motor
Please drop mic and walk out. Perfect answer. Thank you.
nrtv20 is offline
Old 03-27-2018, 03:52 PM
  #300
DARKSIDE's Avatar
yuck...you brought him up...you know Im black right?
DARKSIDE is offline
