Hudy Pan Car Setup Station >
Like Tree3Likes
  • 1 Post By MUDVAYNE
  • 1 Post By haywood
  • 1 Post By miller tyme
Old 03-01-2018, 10:05 AM
Trader Rating: 87 (100%+)
Default Hudy Pan Car Setup Station
So I had an interesting conversation with one of the fast guys at my track this past weekend. He was saying that the Hudy pan car setup station is off when it comes to measuring the camber on my 12th scale car. I have had someone else tell me this as well. Has anyone else heard of this? One guy told me that if I were to use the station for camber, to set it at 2 degrees and it would get me close to the half a degree I was wanting. Just wondering what everyone else's feelings or thoughts were on this? Thanks!
MUDVAYNE is offline
Old 03-01-2018, 10:44 AM
Trader Rating: 24 (100%+)
well easy way to check is use a standard camber gauge to double check it. I don't have that one as it only gives two ride height options, it sets my car really high as in if set to 3mm height with the gauges on it'll be 5.5-6mm
Scirocco is offline
Old 03-01-2018, 10:57 AM
I used the hudy station .and found the same thing with camber settings .. Ive always used an old rpm camber gauge and havent had any issues ...
mb racer is offline
Old 03-01-2018, 11:47 AM
I have the set of CRC graphite gauges so maybe I'll check it against them. I got this as I thought it would be a simple and faster way of setting both camber and toe.
Josh-n-ya likes this.
MUDVAYNE is offline
Old 03-01-2018, 04:10 PM
haywood's Avatar
Trader Rating: 49 (100%+)
Default Setup
I believe the Hudy is off as well. I currently use the Kyosho Pan Car Setup Station and really like it!
Castradamus likes this.
haywood is offline
Old 03-01-2018, 04:44 PM
Trader Rating: 33 (100%+)
Most setup stations will be off compared to a static camber guage. I have found about a half degree differnece between my hudy and the crc graphite guages. I think the reason for this is because how far the tires go in towards the center of the chassis, whereas the setup stations dont. If you take the tires off your car and put them on backwards you generally will see more negative camber as well.
trilerian is offline
Old 03-01-2018, 07:14 PM
Josh-n-ya's Avatar
Trader Rating: 95 (100%+)
I use the setup station for steering and getting the basic camber set. But I always use the gauge with tires on to get my true camber set. The CRC camber gauge works best.
Josh-n-ya is offline
Old 03-02-2018, 05:24 AM
miller tyme's Avatar
tires on is the worst, glue beads and out of round tires throw it off.
beside accuracy is not as important as repetition. I really don't care if I usually run .5 or 0, as long as I can set it the same every time.
I've seen some that replace the kingpin for measurements, that would be the best.... and biggest pain in the @$$
Essnowyt likes this.
miller tyme is offline
Old 03-02-2018, 02:31 PM
Josh-n-ya's Avatar
I havenít had any issues with tires on while using the gauge. Tires wear even. Only when I rely on the Hudy for camber is when I get weird tire wear.
Old 03-02-2018, 02:41 PM
hairymuffin's Avatar
Trader Rating: 103 (100%+)
Camber gauge or can of coke lol
hairymuffin is offline
