LRP Flow X Software Question >
Old 02-26-2018, 01:46 AM
nova2015's Avatar
Default LRP Flow X Software Question
I have a Flow X Offroad, which I am going to fit to a TC run in blinky mode spec class.
Which software, was thinking either 4.2 or 5.2?
nova2015 is offline
Old 02-26-2018, 01:52 PM
nova2015's Avatar
So, did the update last night. The display indicated the update was completed successfully. Attempted factory reset as instructed, but only a solid blue light and no response to throttle input.
The original software was reinstalled,and it works fine again. Thinking perhaps it was a bad copy of the software,I deleted it and downloaded a new one. Same result. Also tried installing 4.2, but same result again. Going back to 3.1 it works fine each time.
Ideas anyone?
nova2015 is offline
Old 02-27-2018, 01:22 PM
Are you using the v3 usb bridge?
jeremy444 is offline
Old 02-27-2018, 02:18 PM
nova2015's Avatar
Yes. Bought it specifically for this purpose. Each time I reinstalled the original firmware it’s fine. Just won’t accept anything else.
nova2015 is offline
Old 02-27-2018, 04:14 PM
Stupid question: did you calibrate your esc again after firmware update?
Also, I myself prefer to factory reset the esc at least 3 times, just to be sure it is truly resetting...
Govert is offline
Old 02-27-2018, 05:31 PM
nova2015's Avatar
Yes. Did it multiple times, and only once did the three lights flash to indicate the reset was successful. When that happened, I did the throttle calibration and it was all fine.
Switched off, and later came back to it to find only solid blue light and no response from ESC. reinstalled original firmware, reset worked first time, calibration was fine, and ESC worked after it was switched off and back on again.
nova2015 is offline
Old 03-10-2018, 11:45 PM
Jochim_18's Avatar
don't reset it just calibrate the esc and radio.
Jochim_18 is offline
Old 03-11-2018, 12:45 AM
gigaplex's Avatar
Uh, no, you need to reset the LRPs whenever you change firmware.
gigaplex is offline
Old 03-11-2018, 01:38 AM
Jochim_18's Avatar
Reason why you have to reset it?
Old 03-11-2018, 03:11 AM
gigaplex's Avatar
The manual tells you to. I'm guessing it's because the settings options change between versions so the saved settings no longer applies to the new firmware.
gigaplex is offline
