Gtp2e street drag set up help. >
Old 02-24-2018, 06:10 AM
DJBABYFINGAZZ's Avatar
Default Gtp2e street drag set up help.
Hi guys first time posting..
I been stuck for awhile on gearing on y gtp2e.I'm looking to see if anyone has the best gearing for 132ft-600 ft street drag.
My set up:
Gtp2e
2200kv,2250kv,2750kv,3200kv tp 4070cm motors as options.
Castle xlx esc
Bar foams 17mm
Currently running a 42 spur and 26 pinion mod 1
4s-6's only
2 Graphine 3s 65c 5000mah
If you had what I have what would you use and how would you set it up?
DJBABYFINGAZZ is offline
Old 02-24-2018, 06:51 AM
great set up.
mine is similiar.
I wouldnt use that 3200kv TP motor with xlx, it will blow the caps off..
hobbywing max5 will work.
what compound BSR foams?
what diff wt are you using for front and rear?
also what transmitter/receiver?
looks like you are on the right track...just have to go out and start making hits.
stick is offline
Old 02-24-2018, 07:42 AM
the rc guy's Avatar
DI.im running same car.. I run a 1500Kv Kershaw designs motor its about 1.5" taller than a 55o.. about 1/4 larger in diam.. Im running on 6 cells..dont run 600 often that 1/4 scale 1/8 mile right..I run 132..ts is 127mph..7 second runs.I run 42 steel spur and 32 pinion you can factor to your desired motor kV from that.we use a combo of sugar water and b4 we use a leaf blower on the track b4 .. no other i use x0-1 tires with solid blown in foam..im running a Kontronic 200amp esc.
the rc guy is offline
Old 02-24-2018, 09:31 AM
you run 127mph in 132ft in 8scale car on 6s? or am I reading this wrong?
stick is offline
Old 02-24-2018, 10:19 AM
R/C Tech Elite Member
TeamSkunkwerks's Avatar
Trader Rating: 138 (100%+)
Talking RC Monster
RC Monster has a setup guide that might help. Select Ofna GTP from the menu & enter info.
https://www.rc-monster.com/brushless/advanced.html
TeamSkunkwerks is offline
