Old 02-08-2006, 10:52 AM   #1
Default Choosing a servo
I am in the process of upgrading servos. I know digital is the way to go as it provides more 'holding power' I am just wondering between speed and torque, what is more important?
I am using this on a 1/10th scale Electric touring car. I have a KO301F receiver.
Whats a good servo out there now? I currently have the KO2173
natskiboy is offline   Reply With Quote
Old 02-08-2006, 10:55 AM   #2
Send a message via AIM to R/C Anonymous
my ANALOG servos work great..Ko Propo 2113's
.06 transit and gobs of torque
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 02-08-2006, 10:58 AM   #3
stiltskin's Avatar
Trader Rating: 102 (100%+)
For touring cars, speed is more important. I'm running a Futaba 9550 digital. Speed is .11 torque is 83 (I think) Car handles great.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 02-08-2006, 11:23 AM   #4
Send a message via AIM to NSantana Send a message via MSN to NSantana
Hi,
I'm answering my own previous post w/ this one but here it goes: I've made the decision of using KO2363 as my primary steering servo for all of my on roads. I've installed the KO2365 on my mtx4 as it is supposed to handle a greater "beating" yet still has the same specs and weight as the 2363. The 2363 is a digital, self centering, ics-compatible FET servo which is great if you're using a KO radio like the EX-10. The futaba s9550 is also a great servo. One of the racers at my LHS uses that one and it gets the job done from what i hear. I would've went that way myself but since I've got the coin to spare, I stay KO...Just personal preference. <<short version>> i'd say go with the KO 2363 or the futaba s9550. Good luck.
NSantana is offline   Reply With Quote
Old 02-08-2006, 12:08 PM   #5
Looks like the 2363 has the same specs as my 2173 only it is digital.
I guess my question is coming form the same spec will i notice a difference with using a digital servo ? Im just trying to justify the cost.
Old 02-08-2006, 12:15 PM   #6
stiltskin's Avatar
The digital servo will track better. Numbers aren't accurate but a comparison would be that an analog servo looks for center 10 times a second. A digital servo looks for center 100 times per second. That means that a digital servo holds its line better.
Tony Rumple
Old 02-08-2006, 12:51 PM   #7
Thanks for the info. I will save some $$ and get digital servo then.
Old 02-08-2006, 02:18 PM   #8
I've had very good results with a KO 2123. It is very fast, very strong and can take lots of abuse without breaking. I've also had good luck with the Futaba 9541. That one is in my 6 year old son's car and he drives it hard, but it has had no problems.
Ira
iblumberg is offline   Reply With Quote
Old 02-08-2006, 02:35 PM   #9
Hebiki's Avatar
Trader Rating: 26 (100%+)
since you are still saving up some $$$... in late march, Ko Propo will be releasing their "low profile" servo.
Originally Posted by Hebiki
yup you heard it here first! Ko Propo does it again!
Specs:
Model Name: PDS-2413 ICS Low Profile Digital Programmable Servo
Item # 30044
Speed: 0.10 sec
Torque: 118 oz-inch (8.5Kg-cm)
Weight: 44.8g
Length: 41mm
Width: 21mm
Height: 25.4mm
S9550 Specs:
Speed: .11 sec/60 deg @ 6V
Torque: 83 oz-in @ 6V
Weight: 1.6 oz (45g)
Length: 1.6" (41mm)
Width: 0.8" (20mm)
Height: 1.0" (25mm)
LIGHTER, FASTER...STRONGER.... dialed!
Scheduled for release late March 2006.
from the Ko Propo servos thread... there's a link in my signature.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 02-08-2006, 03:01 PM   #10
cool servo indeed but not fast enough for me...i like my servos .06-.08
Geoff C.
help choosing car TC5AE Electric Off-Road 18 09-04-2008 08:34 PM
need help choosing koolkidd Electric On-Road 8 05-19-2007 05:57 AM
choosing an ESC... Boltaction Electric On-Road 3 08-04-2006 05:39 PM
Oval 1/10th Scale "choosing A Servo" bst Oval, Larger Scales and More 2 12-28-2004 04:36 PM
choosing car bigbutstupid Nitro On-Road 1 06-21-2002 03:21 AM
