Old 02-27-2006, 08:20 PM   #76
I want it ... I'll just stock-up on Corally tires.
That car looks pimp.
duckman996 is offline   Reply With Quote
Old 02-27-2006, 08:32 PM   #77
tbeardmore's Avatar
Talking Corally SP12X available in the USA E.T.A. (MARCH)
FYI - ALL
I just placed my pre-order today with Corally USA! (First order in the Country - I think)
Call: 407.681.5905 ask for Jeff to place your order NOW and be one of the first in the country to own the New SP12X...!!!
tbeardmore is offline   Reply With Quote
Old 02-27-2006, 08:51 PM   #78
Soviet's Avatar
Originally Posted by tbeardmore
FYI - ALL
I just placed my pre-order today with Corally USA! (First order in the Country)
Who cares???
If you can't run standard tires...you're gonna be hating life...
"You don't get hurt racing little cars..."
-Me
Soviet is offline   Reply With Quote
Old 02-27-2006, 09:00 PM   #79
tbeardmore's Avatar
Originally Posted by Soviet
Who cares???
AAHHHhh - But Kimo Saabi - You don't know I already have an abundance of Corally Wheels & Tires.... Plus it doesn't matter if I can't run standard tires... The Corally Wheels are better anyway (IMO).
Old 02-27-2006, 09:02 PM   #80
AdrianM's Avatar
Will there be a version that takes regular US wheels?
Adrian Martinez
Old 02-27-2006, 09:11 PM   #81
tbeardmore's Avatar
Nope!
Just run the Corally wheels... If your LHS doesn't carry them for you... (which they should if you ask them to) You can call Corally USA direct and have them within 2-3 business days.
Old 02-27-2006, 10:44 PM   #82
syndr0me's Avatar
Trader Rating: 32 (100%+)
My degree isn't in marketing or anything, but it's pretty clear there's a LOT of interest in this car in the US, especially if we can use the wheels we're accustomed to. Hopefully, you know, someone will get it.
syndr0me is offline   Reply With Quote
Old 02-27-2006, 10:51 PM   #83
Jeff Brown's Avatar
Originally Posted by jrrc
Jeff......is it true you will be making a conversion for regular wheels (front and rear)?
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 02-28-2006, 09:31 PM   #84
RacinJ's Avatar
Once you've used the Corally wheels and diff with their wheel clips, you'll never want to use standard rims again.
RacinJ is offline   Reply With Quote
Old 03-01-2006, 01:27 AM   #85
mooony's Avatar
mooony is offline   Reply With Quote
Old 03-01-2006, 05:27 AM   #86
Send a message via AIM to WhoMe
I do not own a Corally. But I had a chance to take a close look at the Corally wheel setup from the gentleman who runs my LHS. All I can say is while sure..the corally wheels arent "common", I find thier design genius. The engineering of the wheels definatly gives the impression that it would be alot harder to break a Corally wheel than it would a standard wheel. Not to mention how easy it looked to remove them...*clip* and its off. I dont think the wheel thing would keep me from buying one.
WhoMe is offline   Reply With Quote
Old 03-01-2006, 11:11 AM   #87
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
Back in the late 80's, an small aftermarket company (can't remember who) use to make a conversion kit which allowed you to use TRC type front tires and an associated diff / axle in the rear.
Basically, the kit includes an aluminum sleeve which the ID was 3/8 and OD was 8MM or 9mm (whatever the OD of the corally rear axle bearing was)
Basically, the sleeve would go over the associated flanged bearing and fit snug into the corally rear-axle bearing holders. Worked great. But the downside was having to shim the hell out of rear axle to space it properly and you had to run either extra long pinions gears or a pinion gear spacer (made by niftech) in order for the center mounted motor to reach the spur gear.
For the front. You got two new alum axles. One side would clip into the hub carriers as the stock one, the other side was machined to to fit the wheel or 5/16 OD. Because of the larger size, the clips no longer held the wheel in place, you used an o-ring.
I really liked my Corally....I actually think C. Doseck ran a corally this way back in the day...That's how I found out about the conversion kit.
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 03-01-2006, 09:32 PM   #88
syndr0me's Avatar
So, what are the compounds of choice for Ozite carpet in Corally's tires? Maybe it's time to buy them now while they're easy to find.
You guys might want to place a big order if these are the only tires we can use. Since I don't have any 1/12th tires, I guess I don't care who makes them or what their design is, so long as they work and can be easily obtained.
Old 03-01-2006, 09:39 PM   #89
Korey Harbke's Avatar
I think Pink rears and silverstar fronts..... I could be wrong though. I just remember seeing something like that on a setup sheet.
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 03-01-2006, 09:44 PM   #90
subman's Avatar
Once you go Corally you never look back...........
...........cept to see who came in second!
The wheels and diffs are true genius, the tires are second to none and this new pan car looks awsome!
subman is offline   Reply With Quote
Corally SP12X franzdebbie Electric On-Road 609 11-29-2009 12:58 PM
Corally SP12x DavidAlford R/C Items: For Sale/Trade 21 06-18-2008 06:19 PM
CORALLY SP12X WC Sigearhead R/C Items: For Sale/Trade 12 10-26-2007 11:30 AM
Corally SP12X F/S jrxsracer R/C Items: For Sale/Trade 10 04-06-2007 02:43 PM
Corally SP12X fastzach R/C Items: For Sale/Trade 8 02-17-2007 12:20 PM
