Old 12-07-2006, 04:37 PM   #196
subman's Avatar
I might have just been the track it was a little rough
subman is offline   Reply With Quote
Old 12-12-2006, 05:00 AM   #197
I broke a lower pod plate as well, someone at the track suggested leaving out the center screw in the t-plate as this is where it broke. anyone else run with only the outer screws in place? I also broke a ride height adjuster, it pushed the bearing through. it was in a tangle, not a wall hit so im not sure why it would have broken.
snowyelan is offline   Reply With Quote
Old 12-12-2006, 01:59 PM   #198
I run without the centre screw, and it does increase rear traction. And yes, it does increase the chances that the t-bar breaks in a crash, but it is still worth it for the better handling.
I have also had a ride-height adjuster break the same way, but it was be being hit directly in the side by another car going full speed. Despite any number of sideswipes of track markers, they have not even moved! I put it down to a freak accident. (The same freak accident that broke the bottom plate too! )
So, after 30-odd runs, my Corally has lost one T-piece because I drove badly and smacked a corner marker - hard. Better than my Trinity, so Im happy. And it handles sooooo well...
SlowerOne is offline   Reply With Quote
Old 12-12-2006, 04:28 PM   #199
subman's Avatar
The car is simply amazing!! I just was wondering if this is a weak point of the car . I am trying to get an al. on made
Old 12-12-2006, 08:58 PM   #200
tbeardmore's Avatar
Originally Posted by Jeff Brown
Aftermarket bumper....... interesting.
Jeff
Hi Jeff - How ya doin' buddy!
Ya, I made a delrin bumper piece that utilizes all four of the front holes... and it works!
I found the "weak" part of the car this week.... as you could probably see from my order Monday....!
Going full speed into the 1st corner... taking the "inside line" going to pass by a "back marker" (lap traffic) for the 3rd time in 3 minutes.... then he decides to shut the door on me and so I just barely clipped the inside barrier and.... YUP... you guessed... straight into the outside barrier..... "head on"...!
Totally ripped all of the electronics off the servo tape... and actually ripped the stapping tape holding the batteries in THROUGH the rear battery slot on the Chassis.... and the front of the car... bumper, front suspesion arms... even those little servo mounts held up..!
So... I guess my little delrin bumper works....?
But .... CRAAP... that hurt!
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 12-17-2006, 03:24 AM   #201
Default T-bar
Hello, is it possible to use another brand of t-bar (asso,trinity...) on the Corally car?
Thank you
benoitrdv is offline   Reply With Quote
Old 12-17-2006, 06:08 AM   #202
protc3's Avatar
i believe the AE T plate will work
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 12-17-2006, 10:19 AM   #203
Thank you
Thank you for the info
Old 12-17-2006, 11:47 AM   #204
subman's Avatar
Thank you
Nope. I just placed a 12x t bar and a ASC. t bar together and they don't line up at all.
Old 12-17-2006, 11:54 AM   #205
fast-ho-cars's Avatar
when will the US version actually be for sale in the US?
fast-ho-cars is offline   Reply With Quote
Old 12-17-2006, 12:06 PM   #206
protc3's Avatar
i thought that they had mounting holes for either T bar.the AE front end and T bar were supposed to be able to work with the car.i could be wrong though
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 12-17-2006, 12:15 PM   #207
Thank you for clarification, maybe another brand will fit?
Old 12-17-2006, 11:26 PM   #208
don't know if these photos are what the kits are coming with? both appear to use the same t-bar
Old 12-17-2006, 11:33 PM   #209
subman's Avatar
They might very well fit then I wasn't aware of the extra mounting holes. I will have to do some more research
Old 12-18-2006, 03:30 AM   #210
Send a message via ICQ to MattW
Both kits do come supplied with the same Corally T bar - 2mm thick. It may be possible to fit Associated T bar, but i think it would be a fair amount of work, as you would need to change the pivots, and the radio tray post would also be a problem.
MattW is offline   Reply With Quote
Corally SP12X franzdebbie Electric On-Road 609 11-29-2009 12:58 PM
Corally SP12x DavidAlford R/C Items: For Sale/Trade 21 06-18-2008 06:19 PM
CORALLY SP12X WC Sigearhead R/C Items: For Sale/Trade 12 10-26-2007 11:30 AM
Corally SP12X F/S jrxsracer R/C Items: For Sale/Trade 10 04-06-2007 02:43 PM
Corally SP12X fastzach R/C Items: For Sale/Trade 8 02-17-2007 12:20 PM
