Old 11-28-2002, 03:29 AM   #1
over gear's Avatar
Trader Rating: 15 (100%+)
Default Soldering iron
I'm looking for a hot yet affortable soldering iron. Any suggestion?
over gear is offline   Reply With Quote
Old 11-28-2002, 07:45 AM   #2
MSB
MSB's Avatar
Send a message via Yahoo to MSB
Exclamation
Above all you must chose a point isolated soldering iron, like ceramic or soldering station. Some ESCs donīt like the AC current of normal soldering irons.
cheers
Miguel S. Braga
MSB is offline   Reply With Quote
Old 11-28-2002, 08:27 AM   #3
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
The 20 dollar 40 watt Weller irons work just fine...
Speedo is offline   Reply With Quote
Old 11-28-2002, 09:42 AM   #4
ottoman's Avatar
any 40 watt iron will do.... but make sure you get the largest "chisel" or "screwdriver" tip for your iron. The more mass in the tip the more heat it will hold and the faster it will solder. This is very important when you solder batterys.
ottoman is offline   Reply With Quote
Old 11-28-2002, 12:20 PM   #5
Send a message via AIM to ZER01
Thumbs up soldering irons
http://www.inlandcraft.com/howto/sol...g_products.htm
overgear, this is the brand I use. I got mine from hobby lobby(craft store).
ZER01 is offline   Reply With Quote
Old 11-28-2002, 03:48 PM   #6
over gear's Avatar
Default Re: soldering irons
proudwinner: which model do you use? where can i buy Inland irons online?
Old 11-28-2002, 04:07 PM   #7
Overgear, I use the 60100 model. Which cities are closest to you and I'll try to help locate a place that sells them.
Old 11-28-2002, 04:09 PM   #8
over gear's Avatar
I live in Reseda, California....how much did you pay for yours?
thanks.
Old 11-28-2002, 04:17 PM   #9
I paid $75+tax for mine. Here's some online stores;
http://www.castlestainedglass.com/catalog.htm#SOLDERING
http://www.google.com/search?hl=en&i...ering+products
Old 11-28-2002, 04:50 PM   #10
over gear's Avatar
Thanks proudwinner... but i am looking for something cheaper...
something like these:
http://www.hobbico.com/tools/hcar0775.html
or
http://www.amazon.com/exec/obidos/tg...&s=hi&n=553006
are they reliable?
Old 11-28-2002, 06:42 PM   #11
popsracer's Avatar
Default Soldering irons
Buy the Iron with the MOST watts that you can afford. 60 or more watts is best.
popsracer is offline   Reply With Quote
Old 11-28-2002, 06:51 PM   #12
Speedo says the 40 watt weller works just fine, if I had to choose between the group I would opt for that one.
Old 11-28-2002, 07:05 PM   #13
Check out the Hakko 456 Super Pro Iron on this page, $18.95 and you can order from the site. Hakko is a brand name that you can trust when it come to soldering.
http://somerstiffany.com/mall/Soldering-Irons.asp
Old 11-28-2002, 07:12 PM   #14
popsracer's Avatar
Default Soldering Iron
proudwinner;
That Hakko Iron is $49.95. Extra tips are $18.95. That's still a good price for anything Hakko.
I paid $99 for my Hakko 907 soldering station. I used an Ungar 100 watt Iron for years and it worked fine. The only thing better about the Hakko is adjustable temperature, 15 second heat-up time and it is easier to change tips.
Old 11-28-2002, 07:25 PM   #15
I thought that was a little too good to be true. Sorry about that. Yes they are good, real good.
Best Soldering Iron? snoopyrc Radio and Electronics 30 11-21-2010 10:52 PM
soldering iron csilve Electric On-Road 26 11-17-2010 08:55 PM
wtb soldering iron pecrichard R/C Items: Wanted to Buy 6 11-17-2010 10:23 AM
Soldering Iron Flash-R.C. Electric On-Road 10 01-30-2005 05:31 PM
soldering iron??? Matt04 Electric On-Road 12 10-11-2003 11:25 AM
