Old 02-07-2006, 10:55 AM   #1
Lord_Darkhelmet's Avatar
Default tc3 chassis tweak
Is it possible for the stock composite chassis to become 'tweaked' over time? If I set the the chassis on a flat surface without wheels on, it doesn't look to be twisted. I should strip the car and check again.
Lord_Darkhelmet is offline   Reply With Quote
Old 02-08-2006, 08:14 AM   #2
Trader Rating: 27 (100%+)
Send a message via AIM to John Stranahan
The motor heat does tend to pull up the right rear corner of the TC3, especially in warmer climates. To prevent this remove the motor from its mount after every heat. This tweak is evident when you check the chassis on a tweak station. The right rear or left front shock collar will be lower after adjustment. Also, when you check the chassis for flatness like you suggest the right rear corner will be elevated.
The new TC4 motor mount should cure this problem on the newer cars.
John Stranahan is offline   Reply With Quote
Old 02-08-2006, 12:50 PM   #3
Aries326's Avatar
Trader Rating: 19 (100%+)
Does the TC4 motor mount fit the TC3?
Point1Drift
http://www.driftercentral.com
Aries326 is offline   Reply With Quote
Old 02-08-2006, 02:19 PM   #4
Mark G's Avatar
Send a message via AIM to Mark G
yes I am 95% sure it does
Mark G is offline   Reply With Quote
Old 02-08-2006, 05:00 PM   #5
I think you could make the TC4 motor mount fit, but you would have to do considerable Dremmel work and drilling. I would get the TC4 chassis. I converted my whole car to TC4 for about $85. See the TC3 thread search for TC3 to TC4 conversion for part numbers.
http://www.rctech.net/forum/showthre...C4#post2049175
and there is a followup post that this one links to with a picture of the mount and the converted car.
This new motor mount and its long brace is very similar to the one I constructed and showed to Barry Baker after he raced in Houston.
Old 02-08-2006, 06:14 PM   #6
Aries326's Avatar
Thanks. I read your very good and detailed post on doing the conversion before. I might have to try it this summer.
Point1Drift
Old 02-08-2006, 06:36 PM   #7
Here is a post where I made a motor mount strap for the TC3 to solve the tweak issue. I did it all with a Dremmel. This is much cheaper.
http://www.rctech.net/forum/showthre...rap#post721598
the metal part I made is sitting on the back of the chassis in the photo that is attached to that post. Earlier I described a motor mount gusset that keeps the motor from sagging.
Here is the original post with another pic.
http://www.rctech.net/forum/showthre...rap#post257262
Old 02-08-2006, 07:59 PM   #8
Mine was when I sold it for parts, I just threw it away it was so bad. I found that right where the motor mounts is where it happens. Youll notice right before the hole under the motor closest to mount it will have a rounded bulge coming out on the bottom.
Motor sags when hot I guess and pulls the chassis?
ZachKipp is offline   Reply With Quote
Old 02-08-2006, 10:10 PM   #9
That mod looks awesome, nice work !
I stripped my car and on a piece of glass the RR of the chassis is up by about 1mm. Not much but probably enough to throw the tweak off.
Old 02-08-2006, 10:13 PM   #10
When you cut the slot with the Dremmel the chassis lays down back flat again.
Aluminum Chassis Tweak Tool/Plate Fervidsea Electric On-Road 9 11-28-2006 09:50 AM
new t2 xray chassis tweak benroc Electric On-Road 45 03-24-2006 06:21 PM
TC3 Chassis and Parts with Tweak Free Modification $40 John Stranahan R/C Items: For Sale/Trade 2 02-11-2006 09:29 PM
Tape -vs- battery brace "To tweak or not to tweak is the question" dawgmeat Electric On-Road 37 11-17-2005 01:05 PM
What does it mean , TWEAK ? Fusion Australian Racing 4 08-07-2003 11:35 PM
