Old 02-06-2006, 10:49 PM   #1
vabroom's Avatar
Default Integy lathe motors
Integy has 4 different lathe motors - 35t, 45t, 55t and 65t. What is the difference between them and which ones can be with 12v source? Of course, it would help if Integy had them in stock!
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 02-06-2006, 11:16 PM   #2
I know the tractor puller motor from LRP is 55T and works @12V at a suitable speed for a lathe.
Kyosho Evolva M3 / Kyosho Lazer ZX-5 SP / Xray T3
aantonis is offline   Reply With Quote
Old 02-06-2006, 11:33 PM   #3
XrayFK's Avatar
You can always just use any old motor, and power it with a four cell pack or your charger if it has a motor run function.
XrayFK is offline   Reply With Quote
Old 02-07-2006, 12:22 AM   #4
Drewdc90's Avatar
Lightbulb
Or you can make a variable voltage controller that will allow you to run a Johnson or Mabauchi motor off 12volts supply and dial the voltage between 2.5v to 12v. Also comes in handy if you want to have differant temp for your tyre warmers
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 02-07-2006, 12:30 AM   #5
XrayFK's Avatar
Most people don't want to spend time fiddling around with electronic components. Although, it wouldn't be that expensive or hard to make. Just find a suitable potentiometer.
Old 02-07-2006, 01:59 AM   #6
Or you can get yourself a ready made.... I use this one from MRT. A bit pricy, but you only get what you pay for.
http://eshop.rcring.com/index.asp?ca...uct&prodid=210
I have seen lots of home made construction creating double the damage of this little thingy....
Old 02-07-2006, 09:23 AM   #7
vabroom's Avatar
thanks guys for the info. i'll try the 55t for now. if that doesn't work, i'll look into getting a new charger/controller.
Old 02-07-2006, 09:44 AM   #8
BeetleBailey's Avatar
I just use an old stock motor. I use the motor run feature on my dyno to run it. It works great.
BeetleBailey is offline   Reply With Quote
Old 02-07-2006, 09:46 AM   #9
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
You will do fine with the 55T....
That is what I have on my Hudy but mine was made by Scott at Banzai Motorsport. Plug it right into the power supply and the perfect RPM for cutting it there.
Hope that helps,
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 02-07-2006, 10:31 AM   #10
vabroom's Avatar
thank you, Mr. shookie. I rather spend the money on the motor and for tires/tracktime than on another piece of equipment.
Old 02-07-2006, 12:23 PM   #11
How many amps is that 55t motor pulling anyways ?
stumper is offline   Reply With Quote
Old 02-07-2006, 12:44 PM   #12
James35's Avatar
Could the 55T be used inside a 12th scale 4 cell car? I don't see why not. I would like it for slower practicing.
James35 is offline   Reply With Quote
Old 02-07-2006, 01:22 PM   #13
Send a message via AIM to rcguy2477
technically yes, but it would be a lot slower than you would think. Just imagine, a stock motor used for a lathe is usually run at 3-4v. To achieve the same rpm with a 55t motor, 12 is needed, approximately triple the voltage.
1989 Mazda Rx7
greddy t04b, megasquirt ecu, PlX wideband, 12x28x3 fmic, 50mm hks clone wg, ssqv bov, Safc, ss oil lines, walbro fuel pump, tubo intake manifolds, ssac exhaust manifold, 3" dp, 550cc primary/720cc secondary injectors, etc.
rcguy2477 is offline   Reply With Quote
Old 02-07-2006, 01:58 PM   #14
Good question. For my lather motor, I tried using a Monster Stock that I had lying around. I powered it with my ICE charger in motor break-in mode. If I tried to make more than just the most microscopic cut, the motor would draw more than 10A and the ICE would shut down.
I'd love to have a motor that would spin reasonably fast even under a bit of load and not draw more than about 8A.
Ira
iblumberg is offline   Reply With Quote
Old 02-07-2006, 07:25 PM   #15
If you would like to decrease the amp draw of the motor, shave the sides of the brushes making them more narrow. My stock motor now pulls 5 amps at the most using specially cut brushes.
1989 Mazda Rx7
Integy Auto Lathe, new 19t motors CCristo R/C Items: For Sale/Trade 5 02-18-2008 03:41 PM
Integy / Eagle Racing MOD Lathe, No Limit ESCs, Motors for sale Cain R/C Items: For Sale/Trade 3 08-13-2007 10:24 AM
Integy 55T lathe motors ManicRC R/C Items: For Sale/Trade 6 03-23-2007 03:53 PM
integy 55t lathe motors GReddy Electric On-Road 2 03-04-2005 06:35 PM
Integy Lathe/ Cyclone2/ 4 mod motors with extras midnight oil R/C Items: For Sale/Trade 13 10-19-2003 10:04 AM
