Understanding F1 Tuning: Let’s break it down >
Like Tree428Likes
Old 03-10-2018, 06:54 AM
  #121
xevias's Avatar
Thank you Rob King. Something you wrote awhile back changed my car from dog poop to absolute gold.
I lowered my front roll center by moving the knuckles higher up on the king pin. Car doesn't push any more and I knocked off a full second from lap times.
xevias is offline
Old 03-10-2018, 11:21 AM
  #122
texastc's Avatar
RobK should start his own thread on F1 he knows his stuff and I use his info a lot. And his blog
texastc is offline
Old 03-10-2018, 11:23 AM
  #123
mleemor60's Avatar
Trader Rating: 28 (100%+)
Where would one find this blog?
G-rem likes this.
mleemor60 is offline
Old 03-10-2018, 03:20 PM
  #124
texastc's Avatar
Originally Posted by mleemor60 View Post
Where would find this blog?
Im trying to remember, rc.F1.blog
Rick Vessell likes this.
texastc is offline
Old 03-10-2018, 05:49 PM
  #125
Trader Rating: 17 (100%+)
Unfortunately he doesn't post as often as he used to.
astgerma52sp is offline
Old 03-12-2018, 09:48 AM
  #126
liljohn1064's Avatar
Originally Posted by cementsurfer86 View Post
Has anyone tried the Gravity premounts on gray carpet?
I'll be giving my personal car a shakedown run on Wednesday with them, but wanted to hear from some of you guys as well.
They are predictable, but a bit slower than CRCs. They are a bit stiffer in the sidewall and it was cold when I ran them. I really liked them and need more time to get used to them.
liljohn1064 is offline
Old 03-12-2018, 10:21 AM
  #127
cementsurfer86's Avatar
How long did it take you to break them in? it's been years since I've run a formula car, and while I'm probably off on setup, it was a HANDFUL to drive.
cementsurfer86 is offline
Old 03-12-2018, 10:40 AM
  #128
Trader Rating: 24 (100%+)
is everyone running at least 1* toe out?
phatboislim is offline
Old 03-12-2018, 11:08 AM
  #129
It took a few packs honestly to completely get rid of the shine and get a nice even run in surface. You may want to scuff them with a scotch brite pad or something mildly abrasive.
cementsurfer86 likes this.
Old 03-12-2018, 05:54 PM
  #130
Total toe??????? Yes. Im just under .5 per side.
freebird is offline
Old 03-12-2018, 06:25 PM
  #131
Tim Neja's Avatar
I'm currently running 2.5 degrees of toe out and I've seen MUCH more!! This seemed to stabilize the car in the straight and ALSO gave me more turn in at high speed!! BOTH of which I never seem to have enough!! I DON'T want to have to run drag brake--as If I can get the car to ROLL the corner--it's faster! Drag brake I only use as a LAST resort for turn in!! FWIW
Tim Neja is offline
Old 03-12-2018, 07:54 PM
  #132
Sounds like an easy car to pass under brakes!
ixlr8nz is offline
Old 03-12-2018, 08:08 PM
  #133
Dan
Dan's Avatar
Trader Rating: 74 (100%+)
Too much exclamation points.
Dan is offline
Old 03-12-2018, 08:23 PM
  #134
Tim Neja's Avatar
If you're braking--you're going slower---no pass!
Tim Neja is offline
Old 03-12-2018, 08:49 PM
  #135
EMU
EMU's Avatar
Brakes only slow you down! Until you break.... then you go nowhere.
EMU is offline
