Understanding F1 Tuning: Letís break it down >
Like Tree427Likes
Old 05-25-2019, 01:25 PM
  #541
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by dman18t View Post
Before spending tons of money on the gear diffs, just try a ball diff built with Tamiya AW grease. You still have the adjustability and doesn't cost you a thing. Works just like a gear diff with high k fluid.
AW grease is inconsistent for diffs. It does weird stuff as it gets hot. Try the pink VG Tamiya grease, which is a diff grease, and is even thicker than AW.
https://www.tqrcracing.com/shop/prod....asp?p_id=5832
Rick Vessell likes this.
robk is offline
Old 05-25-2019, 03:12 PM
  #542
Good tip!
dman18t is offline
Old 06-03-2019, 01:20 PM
  #543
Nice
)EIB( is offline
Old 07-08-2019, 04:19 PM
  #544
Trader Rating: 21 (100%+)
Struggling, canít get enough on power steering. Xray x1
Front
Camber 2.5, caster 9,
soft front springs
additional weight 20 gr
ride height 4.8
rear
2.5 center spring
25 wgt oil
xray black side springs
3000 wgt side tubes
rear height 5.2
Transverse battery, spec tires volante M, volante hyper rears. Any thoughts?
photeckk is offline
Old 07-08-2019, 06:00 PM
  #545
R/C Tech Elite Member
JayL's Avatar
rare to have a track that has a on power steering layout
surface?
sauce?
6 caster, thicker side tube fluid, looser/thinner diff
LonnyJ1950 likes this.
JayL is offline
Old 07-08-2019, 09:28 PM
  #546
Asphalt bumpy, low to medium grip with ulti 1 to 5
photeckk is offline
Old 07-09-2019, 01:04 AM
  #547
Check the front and rear droop. Droop seems to be a really important setting on F1s
man1ac is offline
Old 07-09-2019, 02:47 PM
  #548
Front
soft front springs
ride height 4.8
rear
2.5 center spring
25 wgt oil
3000 wgt side tubes
rear height 5.2
How are your front tyres wearing? With 2.5 Camber I would expect the contact patch to be well over on the inside edge. Try 1.0 Camber, if you havenít already.
robk and photeckk like this.
malkie is offline
Old 07-09-2019, 03:09 PM
  #549
MikeR's Avatar
Trader Rating: 15 (100%+)
Front
soft front springs
ride height 4.8
rear
2.5 center spring
25 wgt oil
3000 wgt side tubes
rear height 5.2
In my 25.5 car I used the medium soft fronts at Cal Sunday. Plenty of steering, very easy to drive through all the corners I would just try the MS fronts as the M's are pretty pushy.
MikeR is offline
Old 07-10-2019, 06:01 PM
  #550
JayL's Avatar
Tires are so weird
If I run tamiya fronts my car will push into a wall
If I run Medium Volante it will loop out because those tires have mega mega steering, even more than MS
JayL is offline
Old 07-10-2019, 06:19 PM
  #551
MikeR's Avatar
Originally Posted by JayL View Post
Tires are so weird
I can't argue against that. For asphalt it just comes down to so many factors- track temps, track surface (slurry/porous asphalt/?), track prep/treatment. Always always best to use what the fast guys at that track are using. If I ever visit your track you know I'll have to use your tires. 5-6 different tracks I've visited and they all require different tires so now I ask what tires are best when I go to new tracks. A lot like off road 2wd buggy!
But If you run the same track over and over then you really never have to deviate from the 'best' tires.
Markus and Jethroz like this.
MikeR is offline
Old 07-12-2019, 05:48 AM
  #552
Without searching through this thread. Has there been any discussion on roll center? Front or rear.
old_dude is offline
Old 07-12-2019, 09:13 PM
  #553
Iíve been using this simple guide at the start itís so great!
ChadoSan is offline
Old 07-19-2019, 06:00 PM
  #554
redmonster27's Avatar
Trader Rating: 34 (100%+)
Default Hudy tires
Has anyone tried the hudy f1 tires on crc black carpet description says there made for carpet or asphalt but find that hard to believe
redmonster27 is offline
Old 07-21-2019, 02:00 PM
  #555
Trader Rating: 37 (100%+)
I think they are the same as the Gravity Tires, which I think are Ride rubber, not sure on that though. If they are the same as the Gravity, they do work on both well.
chensleyrc1 is offline
