Understanding F1 Tuning: Letís break it down >
Like Tree382Likes
Old 10-30-2018, 04:59 PM
  #436
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Dan View Post
Also the weave of the CF too. I had a CRC F1 also but probably didn't register as much time as I should with that car. It was great on carpet but definitely a much stiffer CF composition and frontal area than say.... a carbon TRF102 chassis (not counting the T-bar, just chassis material)
TRF102 cars have a thin chassis, maybe 2.5mm,? 2.25??? In any case, it is flexy for sure.
robk is offline
Old 10-30-2018, 05:01 PM
  #437
robk's Avatar
Originally Posted by JayL View Post
My Roche with Carbon was amazing for CTS on Gray last year. Much better than my xray with alum was the year before.
Oddly enough, I liked aluminum on high bite gray carpet. Our old track had IIC carpet from a few years back, and I liked it there.
robk is offline
Old 10-30-2018, 08:12 PM
  #438
rcguyfpr's Avatar
Trader Rating: 46 (100%+)
oh shoot. I think you are referring to Stockton 209. Maybe I shouldnít switch to aluminum then. Oh well, I will try to make it work.
rcguyfpr is offline
Old 10-30-2018, 08:48 PM
  #439
Dan
Dan's Avatar
Trader Rating: 68 (100%+)
Most of the winners have been on aluminum at 209, but EJ has won a few with his carbon TOP F1 too.
Dan is offline
Old 10-31-2018, 08:00 AM
  #440
Trader Rating: 87 (100%+)
Subscribed
MUDVAYNE is offline
Old 10-31-2018, 10:22 AM
  #441
R/C Tech Elite Member
JayL's Avatar
Originally Posted by rcguyfpr View Post
oh shoot. I think you are referring to Stockton 209. Maybe I shouldn’t switch to aluminum then. Oh well, I will try to make it work.
Yep 209. Won that CTS with an almost box stock setup, stock springs etc, far different than my asphalt setup.
I prefer pit 574/575 there, I tried the sweeps, volante, and 571/572 for that race and 574/575 were faster.
The nice thing about the roche is that one piece servo mount, so when you run the shim than connects the rear of it to the chassis it really stiffens the chassis up, I only run that shim on carpet.
My Buddy Brandon won with the Roche carbon at a CTS race on Black carpet as well
JayL is offline
Old 11-08-2018, 12:39 AM
  #442
Trader Rating: 16 (100%+)
Default Traction roll on black carpet
Need some tips on how to avoid traction roll. Iím running 574/575 tires. Iím gluing the front side walls and a bit of the contact patch. I sauce full front and rear. My car just keeps rolling. I run 9 caster and 2 of camber. Iím not sure if I need to run soft springs or hard springs (tried both=same result) for the front or side.
Any tips?
photeckk is offline
Old 11-08-2018, 03:47 AM
  #443
fat500's Avatar
Trader Rating: 35 (100%+)
try adding spacers to the ft or rear to widen the car. I use 1mm tc shims on each rear wheel when I get traction roll and solves the problem. you wont roll but you will loose a small amount of grip. start with .5mm and go from their.
photeckk likes this.
fat500 is offline
Old 11-08-2018, 04:06 AM
  #444
hanulec's Avatar
Trader Rating: 28 (100%+)
Any tips?
If you don't run full front sauce do you traction roll?
dawgmeat likes this.
hanulec is offline
Old 11-08-2018, 06:33 AM
  #445
Rick Vessell's Avatar
Any tips?
Do you have 571/572 tires? They will take away some of the aggressiveness. Soft front and side springs also. Less front camber 1.5-1.0.
photeckk and JeffofSpace like this.
Rick Vessell is offline
Old 11-08-2018, 07:01 AM
  #446
Dan
Dan's Avatar
I used to run 574/575 on gray carpet and it was great. Since moving to black carpet, it was a bit too aggressive and I ultimately went back to 571/572 due to higher chance of traction roll.
Sometimes I'll still have too much front traction just cleaning off the front tires with tire cleaner on 571. What I found is sometimes I don't even clean the front tires fully or just lightly sauce 1/4th of the front tire and it gives me still plenty of steering while not traction rolling.
Sauce has a big effect on traction roll. I never sauce full fronts.
Rick Vessell likes this.
Dan is offline
Old 11-08-2018, 07:58 AM
  #447
MikeR's Avatar
Trader Rating: 15 (100%+)
Any tips?
Are you running at TQ? We are using 74/75 as well. How much of the contact patch have you glued? May not have been enough. We are at 4mm and some others are at 5mm. That way we can still full sauce the tires to keep the carpet grime off.
MikeR is offline
Old 11-08-2018, 10:05 AM
  #448
I do run at tq, my name is Carlos...Iíve applied about 2mm of glue to the front. Iíll apply some more glue...how about oils? Or ride height? I run 4.2 in the front and 4.6 in the rear.
My my car is a Roche, so the front is wider than the rear.
I have tried 71/75, but I canít keep up with the fast guys (although traction or going to two wheels slows me down more). Iíll try these tips...
photeckk is offline
Old 11-08-2018, 10:51 AM
  #449
Dan
Dan's Avatar
Yeah, more glue up front is a must on black carpet. I would lower the ride height in the rear a bit more too.
Dan is offline
Old 11-08-2018, 08:38 PM
  #450
JeffofSpace's Avatar
Yep. Camber. I canít run more than 1 degree on black carpet.
JeffofSpace is offline
