Understanding F1 Tuning: Letís break it down >
Like Tree382Likes
Old 02-05-2018, 04:59 PM
  #31
Nuno Gancho's Avatar
Thanks for a Xray X1 how would you check car weight balance as a complete car or check rear pod and front separately.
What will be the effect of adding weight on front or rear thanks
Nuno Gancho is offline
Old 02-05-2018, 05:18 PM
  #32
I always check as a complete car since that is how it races. Plus the spring weights, droop, etc will place downward force differently and you want to know that also. I used 4 point one with a scale under each tire.
Static weight affects the car in proportion relative to front/rear and side balance and its disposition. Generally, weight in the front helps with steering and weight in the rear helps with rear traction. But like I said it's proportional and relative to what the car is doing.
In other words, its not like weight in the front stays in the front. For example, as you accelerate weight is shifted rearward you will have to factor that both in setup and the way you drive.
mstrfahrenheit is offline
Old 02-05-2018, 05:40 PM
  #33
Thanks will you play with shims in the motor to help rear side to side balance
Old 02-06-2018, 03:35 AM
  #34
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
This thread must not apply to F1 on rubber tires on black carpet because I haven't heard anyone talk about glueing side walls yet.
Rick Vessell likes this.
hanulec is offline
Old 02-06-2018, 04:16 AM
  #35
How is this helpful?
Why not just share what you know about tuning with glue?
mariob62 likes this.
sps3172 is offline
Old 02-06-2018, 05:45 AM
  #36
texastc's Avatar
glue the sidewalls along the ridge of the tread. just a thin bead.
texastc is offline
Old 02-06-2018, 07:49 AM
  #37
Rick Vessell's Avatar
That's just FJ's normal speaking voice.
He doesn't know about glue anyway, he puts tape on his sidewalls.
I too have tried tape, it's easy, adjustable, and can be undone which glue can't. I have used glue also. With glue I go up to the ridge in the sidewall for the fronts. Rears depend on the grip level but have gone up to the ridge on them also.
Rick Vessell is offline
Old 02-06-2018, 09:14 PM
  #38
xevias's Avatar
Please show an example of using tape instead of glue. What is the procedure?
Does this tape method also work with TC tires?
xevias is offline
Old 02-07-2018, 08:14 AM
  #39
The tape is used for hockey, it's clear and very tacky/stretchy.
To use, cut a section long enough to cover the circumference of the tire. Apply one edge of the tape to the tire at the ridge between the sidewall and tread. Work around the tire until it meets up again. Trim excess and fold down against the sidewall towards the wheel.
TC tires have very short sidewalls so I doubt this would work.
sps3172 and xevias like this.
Old 02-07-2018, 08:22 AM
  #40
hanulec's Avatar
much like touring car, if you don't have a solution for your front tires and gluing/taping -- it doesn't matter what setup you use. CA glue is maybe the largest tuning aid right now.. (sadly). once you have your glue height right then you can consider all of the things posted on the first post...
Rick Vessell and sps3172 like this.
hanulec is offline
Old 02-07-2018, 10:05 AM
  #41
Trader Rating: 23 (100%+)
For the record, i can use Hudy tires on black carpet without gluing and it works well. CRC tires i have to glue.
Speaking of CRC tires, anyone have a solution to the asinine wobbling of their front tires?
phatboislim is online now
Old 02-07-2018, 12:27 PM
  #42
I run Gravity tires on black carpet and I don't glue/tape my fronts. Lap times are even with the fast guys at my track. Might be cause of the chassis I run though, a yokomo yr-10f
likea45 likes this.
rezin is offline
Old 02-07-2018, 12:43 PM
  #43
texastc's Avatar
Hate to say it but either reglue them to the rim or buy some more, I think there was a bad batch last year, we had a lot of wobbly front tires at my local track.
texastc is offline
Old 02-07-2018, 01:50 PM
  #44
Zerodefect's Avatar
You can cut a slit in the CRC sidewall and stick a hook pic in there to grab the foam and reset it. Then just apply a little CA to the sidewall to glue up the slit you made.
It's easy if the foam is bunched up really badly from a hard crash and has a huge sidewall bump. If it's ok but wobbly, that's a bit harder.
liljohn1064 and texastc like this.
Zerodefect is offline
Old 02-07-2018, 02:23 PM
  #45
We use the Gravity G-spec tire in our F1 class at Prolevel RC in St. Louis. Glue seems to be driver dependent with these tires. Some of us don't use any.....other guys flip and flop all over the place if they don't glue the sidewalls, even with the Gravity tire. In our case, the brand of chassis doesn't seem to be the determining factor in terms of whether to glue or not.
Also, I appreciate the info on taping.....I'll be more inclined to experiment now that I have a non-permanent option.
In retrospect, the comment from hanulec was indeed helpful....It got the conversation started in terms of F1/Carpet setup info. I stand corrected.
sps3172 is offline
