Understanding F1 Tuning: Letís break it down >
Like Tree430Likes
Old 08-27-2018, 08:27 PM
  #406
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Dan
rob, on black carpet, are you still using an LCG pack?
I never used one other than practice. Most of the time I like the regular shorties since traction is pretty high most of the time around here. I have been to places where the conditions have less bite, and the lcg has worked fine. I'm sure it can work in high traction too, but you may have to make some changes.
robk is offline
Old 08-27-2018, 08:38 PM
  #407
JeffofSpace's Avatar
On the vbc we put about 10g on the rear pod and it likes more than 10g extra in addition to the 30g brass lower suspension mount up front. All give the car more rear grip and more steering. Totally depends on the chassis.
JeffofSpace is offline
Old 08-28-2018, 02:13 AM
  #408
Holmestead's Avatar
Great info, thanks all
Holmestead is offline
Old 08-28-2018, 08:59 AM
  #409
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
I'd recommend people use their suspensions to dial in and weight as a fine tune.
On Saturday I built a new Roche Rapide F1 Evo kit at the track (speed world / CTS finale). In my first pack (setup like carpet) it was junk. Pushed going in. Loose going out.
I proceeded to go out for pack two with both dampener tubes disconnected and a 1.5mm wrench. I full sauced fronts. Not much better. Added two turns on side springs. Better. Added two more turns, now much better. Added one damper tube .. even faster. Second tube. Fast/faster but now loose. Removed second tube. Added another full turn on side spring. Fastest yet.
hanulec is offline
Old 08-28-2018, 09:24 AM
  #410
F N CUDA's Avatar
Trader Rating: 34 (100%+)
Thursday black carpet practice nite threw down my XRAY X1 with set up that was good when I put it away a couple weeks before.
Mine too was now pushing into and loose out of corners. Full sauce front and rear.
Let some traffic lay down some laps, car was better but remembered I had a couple different pairs of glued fronts, one sidewalls only, one set sidewalls and tiny bit on outer edge of contact surface.
By the end of the night grip was so hi that I glued a tiny bit more of the contact surface to keep from grip rolling, this way I can stay with full sauce fronts, super dialed but can almost guarantee I will be using the non glued contact surface tires at the beginning of the next day out just to get steering until traction comes up.
In the past I was half sauce, 3/4 sauce, full sauce etc.
Now I've got a few sets (had them already) with the glue as the traction factor and full sauce is the go to.
Gonna see how that plays out this week.
F N CUDA is offline
Old 08-28-2018, 09:57 AM
  #411
hanulec's Avatar
Black carpet and needs for glue kinda kills all setup...
Rick Vessell likes this.
hanulec is offline
Old 08-29-2018, 05:22 AM
  #412
Holmestead's Avatar
This thread has been invaluable to me. I've only been dabling with F1 since March or so, but I've gone from sloppy 21/22 second laps, to consistent mid to low 19s, and just today consistent mid to high 18 second laps, with a PB of 18.3! No doubt a lot is practice, but learning about chassis handling, and tyre selection etc has made it a lot easier, no doubt a lot less frustrating, and in turn making it a lot more fun for me! Thanks for all the knowledgeable input!
Dan.
robk, F N CUDA, mariob62 and 1 others like this.
Old 08-29-2018, 08:26 PM
  #413
Totally agree. I dig this thread!
mariob62 and Holmestead like this.
Old 10-10-2018, 07:48 PM
  #414
Trader Rating: 94 (100%+)
Rear axle spools - does anyone know who make a metric version? everything i've found is for imperial sized bearings. thanks.
Markus is offline
Old 10-10-2018, 08:33 PM
  #415
Dan
Dan's Avatar
Trader Rating: 76 (100%+)
TRF103 F104 METRIC TO 1/4" AXLE ADAPTOR SET with 1/4" bearings - Exotek Racing
Maybe this might work?
Dan is offline
Old 10-11-2018, 06:34 AM
  #416
J Lee's Avatar
Here, oops no URL allowed. search, HighvelocityRC on FB
J Lee is offline
Old 10-11-2018, 08:27 AM
  #417
Thanks John. I've got there 1/4" one already. I asked if they had a metric one but they don't have one yet. Thanks Dan. I will try the exo chango. so I can use my regular items on my tamiya car.
Markus is offline
Old 10-11-2018, 08:38 AM
  #418
Leester's Avatar
Trader Rating: 23 (96%+)
Default Conversion
This Exotek conversion works great! 3 or 4 of them running at our track. Inexpensive way to convert to the gear diff on a Tamiya car.
MikeR likes this.
Leester is offline
Old 10-11-2018, 09:45 AM
  #419
bd007's Avatar
What or how do you turn the side springs? What does that do?
bd007 is offline
Old 10-11-2018, 09:57 AM
  #420
hanulec's Avatar
f1 are just like a 1/12th. read more here-
http://site.petitrc.com/reglages/rctips_112_summary.pdf
bd007 likes this.
hanulec is offline
