Understanding F1 Tuning: Let’s break it down >
Like Tree428Likes
Old 04-11-2018, 06:06 PM
  #241
R/C Tech Elite Member
JayL's Avatar
JayL is offline
Old 04-11-2018, 09:38 PM
  #242
JeffofSpace's Avatar
Thanks much!
JeffofSpace is offline
Old 04-12-2018, 08:35 PM
  #243
Jedd's Avatar
Trader Rating: 25 (100%+)
I have one question in regards to the F1 class has anyone done any testing or has info on the chassis either carbon or Aluminum, I 'm in the process of building two Team Associated F6 and would like to hear the pros and cons of both on CRC Black carpet with high grip.. thanks for any info you can give..
Jedd is offline
Old 04-12-2018, 09:43 PM
  #244
Tim Neja's Avatar
Most seem to prefer the aluminum chassis for carpet because the bite is so much higher than asphalt--it keeps the car from flexing too much and allowing the suspension to work to get maximum steering and corner speeds. Outdoors on asphalt, the bite is not so extreme--so having the chassis flex and help keep the rear end planted while dialing in your steering seems to be the key!! Of course, car setup is paramount for either scenario!! Your mileage may vary!!!
Tim Neja is offline
Old 04-12-2018, 11:01 PM
  #245
Trader Rating: 37 (100%+)
On black carpet, aluminum helps keep the wheels on the ground, carbon seems to traction roll more. The benefit of carbon though, is quicker steering. If you can drive the car with carbon and not flip, it seems faster. But, that is very hard to do, lol.
chensleyrc1 is offline
Old 04-13-2018, 08:22 AM
  #246
Jedd's Avatar
Thanks for all the great info , would you suggest one aluminum chassis over another??
Jedd is offline
Old 04-13-2018, 08:42 AM
  #247
Trader Rating: 24 (100%+)
From running tc and 12th on black carpet....it all comes down to setup. If you're only gonna be running on black carpet just go aluminum, more for peace of mind
phatboislim is offline
Old 04-14-2018, 08:31 PM
  #248
Dan
Dan's Avatar
Trader Rating: 74 (100%+)
Anyone done extensive testing with a gear diff and friction peg ball diff to see which was faster?<br />
<br />
I'm getting almost identical lap times with the gear diff being a smidge faster and consistent, but barely so. Just wanted to hear from someone who has tested both.
Dan is offline
Old 04-14-2018, 08:43 PM
  #249
vadersing's Avatar
Default Bitty Design Body for F1
What is the difference between Bitty Design Type6C and Type6R body? Steering? Stability?
vadersing is offline
Old 04-15-2018, 07:33 AM
  #250
hanulec's Avatar
Trader Rating: 28 (100%+)
<br />
If you have the traction... A spool axle is nearly unbeatable. A 1/12 axle fits!
Pegs in diff (all pegs) is second best be heats up and changes thru the run.
Both are 10g lighter than a gear diff.
hanulec is offline
Old 04-16-2018, 01:31 PM
  #251
robk's Avatar
Trader Rating: 22 (100%+)
How has the spool axle held up with the heavier rubber f1 tires?
robk is offline
Old 04-16-2018, 04:27 PM
  #252
texastc's Avatar
I haven't had any issues at all
texastc is offline
Old 04-16-2018, 06:24 PM
  #253
I'll stick with a Fenix Gear Diff. Also stick with Carbon Fiber Chassis.I'm amazed at the pinned diff and the pegs making a come back. When I first started racing all the 1/12th cars came with a straight axle. And the peg Idea came from Team Pit stop for his off road chain drive transmittion. Things just never die in r/c?
Giorgio likes this.
BullFrog is offline
Old 04-16-2018, 08:55 PM
  #254
miller tyme's Avatar
I came across a TPS new in package chain the other day while going through some boxes. Great transmission, which I still had one.
miller tyme is offline
Old 04-17-2018, 12:57 PM
  #255
KINGZJ's Avatar
what parts are you guys using to create a spool axle on your f1?
KINGZJ is offline
