13-T Reedy Ti World's Edition Timing? >
Old 01-18-2018, 02:05 PM
Default 13-T Reedy Ti World's Edition Timing?
I installed a 13-Turn(double) Reedy Ti World's Edition Motor in my M-06 chassis. I want to set the Timing to 0. I don't remember what/where the stock timing is/was.
-I have to set the Radio in Reverse to run forward.
Anyone had this motor and remember what the stock timing should be set to?
Thank You
GuyIsDamGood is offline
Old 01-18-2018, 02:49 PM
Any brushed motor has 0 timing when the brushes are 0 degrees from the middle of the magnet.
30Tooth is offline
Old 01-18-2018, 05:09 PM
Thank You
I remember a rule of thumb in the brushed motor days to always run a minimum of 6 degree advanced timing. It has to do with the width of the brush and when it first touches the segment on the commutator to activate that pole on the armature. A 13 double is a mild modified motor and you can move up to 15 or 20 degrees advance timing with these batteries we run now. I believe the motor originally was shipped with 6 degrees advance timing.
davidl is offline
Old 01-20-2018, 03:52 AM
Thanks for the info 30tooth and davidl.
I will try it all out.
Old 03-09-2018, 02:49 AM
I gave-up on the Reedy 13-T Brushed Motor. I will install one of my other brushed motors in the chassis.
Thank You
