RS Gen 2 1S
Old 01-11-2018, 05:33 PM
Einsman's Avatar
Default RS Gen 2 1S
So I have done all the settings on hotwire 2 to run a 1S battery, but when I turn it on it powers up the servo, receiver, and transponder just fine and I can turn the wheels, but there are no LED lights and I get no throttle.
Einsman is offline
Old 01-12-2018, 11:00 AM
Trader Rating: 24 (100%+)
believe randy pike is on rctech in the manufactures forum, a local had the same issues and I don't remember the fix myself but he did switch to a hobbywing the next race
Scirocco is offline
Old 01-12-2018, 04:01 PM
You running a dc booster?
eazy70 is offline
Old 01-13-2018, 05:25 AM
Needs a booster. Where the voltage cutoff can be set for 1s it still won't run the motor that way. New Hobbywing 1s esc's have a built in booster and it can output 6v or 7.4v to the receiver.
old_dude is offline
Old 01-13-2018, 05:56 AM
Almost every manufacturer has esc with a built in booster. New rs pro black edition 1s is a very nice unit.
eazy70 is offline
Old 01-13-2018, 07:01 AM
SLOWINSLOWOUT's Avatar
Trader Rating: 20 (100%+)
If you need a booster Steve, I think I have a few. Will bring on Sunday.
SLOWINSLOWOUT is offline
Old 01-13-2018, 09:30 AM
howardcano's Avatar
Trader Rating: 37 (100%+)
The RS Gen2 1s that I have here for testing has a built-in booster: 4.2V in, 6V out.
Check for correct output voltage if you have a voltmeter.
EDIT: SEE post #13.
howardcano is offline
Old 01-13-2018, 11:25 AM
The old gen 2 will work with out a booster. The booster has nothing to do with the motor running it just gives enough voltage so the servo works properly. I ran an old Gen 2 for the longest time before the new small hobby Wings came out
chad508 is offline
Old 01-15-2018, 05:39 AM
Howard: What is the model number for the unit you have to test? I have googled and come up with the Pro 1s but its literature states that it needs an external booster or receiver pack.
Thanks in advance.
old_dude is offline
Old 01-15-2018, 05:47 AM
Thanks in advance.
I will back up on this. The literature (shared) says the Pro needs a booster for 1s operation. It does not detail the Pro 1s separately. I have not found any info on the 1s that details its specs.
old_dude is offline
Old 01-15-2018, 01:05 PM
Hobbywing makes a nice booster for 25 bucks if didn't get the 1s. If it doesn't say 1s allover the esc label then you didn't get the right one. It's in a black case. Not to be confused with the RS which was only 2s but could run 1s with a booster
Bubonic-X is offline
Old 01-15-2018, 01:54 PM
There is a Pro and a Pro 1s. Both are in black cases but as stated the 1s has that printed on it in big letters.
old_dude is offline
Old 01-15-2018, 04:39 PM
howardcano's Avatar
Thanks in advance.
I apologize for my error. The latest model I tested is not labeled "Gen2"; it is the "RS Pro 1S Black Edition", #TT1161.
Thanks for pointing out the discrepancy!
Old 01-17-2018, 05:41 AM
So guys, the new RS PRO 1s does it work without booster or not? If it is called so I think it should have booster built in.... Who can answer ?
moraccio is offline
Old 01-17-2018, 06:06 AM
The new rs pro 1s DOES NOT need a booster. I have one and it's a great esc, you will notice more power from yoir same combo.
eazy70 is offline
