Old 02-05-2006, 10:49 PM   #1
SammyZ's Avatar
Trader Rating: 138 (100%+)
Default Battery Maintenance Tips
Hi guys,
Ive been out of the hobby for a couple years and Im just getting back into it. I know back in the day we had rc2400's and 3000's just came out. I was told that these packs could NOT be used more than once a day, and required discharging, So i got a tray. Now they have 3300's and 3600's 3800's! Im about to pick up a couple matched gp 3300's and I was told NOT to discharge these.
basically I want to know what you guys are doing with your packs, I plan on charging these up on a Novak Millennium 1.20 or Pro. If you do recomend discharging, what do I stop discharging at? I.e: voltage cutoff?
Thanks!
SammyZ is offline   Reply With Quote
Old 02-05-2006, 11:11 PM   #2
Superkarter's Avatar
These new packs can be used more than once a day.
They don't need discharging between charges but oncassionally I chuck mine on The Novak smart tray just to equalize the cells.
The chargee atomatically cutsoff at 5.4 volts
Hope this helps
Superkarter is offline   Reply With Quote
Old 02-06-2006, 12:56 AM   #3
AngryAsian's Avatar
From memory...
Equalise the cells before you charge them.
For 3300's charge at 5A with around 20mV cut-off for the whole pack. You can play around with the cuttoff as you're aiming for around 55deg C at the end of a charge.
For 3800's charge at 6A, with a 30mV cut-off. Again, with an end charge temp of around 55degC.
After use, tray them down to .9v per cell or 5.4V for the entire pack. If Storing for more than 2 weeks, put 500Mah charge in them.
Before your next charge, take them down to .9 on a tray and go!
No need to discharge between charges nor to equalise. Just do it at the start of your race day.
I've been using these guidelines for a while. From memory i think i pulled this from the SMC site, or might have been Harris RC. Try either one for charging advice.
AngryAsian is offline   Reply With Quote
Old 02-06-2006, 09:11 AM   #4
krisnata's Avatar
Location: Everybody wants to go to Heaven..... but Nobody wants to die
aaaaaaahhhhh!!!!!
when I bought 3600 mah battery , a week later they come up with 3800.
then when I was thinking to get 3800, they came up with 4200.....
and now before getting my hands on 4200, rumors said 4500 will come.....
pheewwwwww....... when is it going to stop...
I think I'll go crazy with this .......
krisnata is offline   Reply With Quote
Old 02-06-2006, 10:52 AM   #5
SammyZ's Avatar
great, thanks for the advice! I am looking to get a smart tray but at $80, its quite a rip off . Maybe i will just use a Indi tray and measure the voltage with a cheapo volt meter.
Old 02-06-2006, 11:06 AM   #6
B18,,
No need to go out and buy a novak smart tray,a better choice is the Tekin battery doctor it's cheaper and works better than the Novak,all you need to do is charge at 6 amps your looking for 130 degree's at peak,after you run discharge the pack down to .09 per cell and store,the day before you race again, place two packs in the tekin tray and let them sit there until your ready to charge them,this will equalize the packs and they will be ready to charge,again 6 amps 130F degrees at peak.
Hyper1 is offline   Reply With Quote
Old 02-06-2006, 11:11 AM   #7
Originally Posted by krisnata
aaaaaaahhhhh!!!!!
Battery development like anything is an ongoing process,it'll never stop,it has been this way every since I started racing back in the early 90's.just rotate your batteries once a month or so and it will keep cost down and fresh packs in your box,most tracks should have a limit on the cells you can use,right now it's 3800's until sept of 06,so there's no use in going out and buying anything more.
Old 02-06-2006, 11:15 AM   #8
Trader Rating: 16 (100%+)
Since this is about batteries, I would like someone to tell me HOW to set delta peak (has always been my problem)
I have some old 3300 and 3700........using Reedy Quaster Pro and ICE...they have the options from 0mv (or is that called DELTA PEAK)....to 10mv.....from ICE manual, said if I want to peak detection to be more accurate I should set the MV to a higher level ( 8 or 9 delta peak) but on my reedy manual, it said 3300 use about 5MV....when I charge both batteries at 3 or 4 or 5MV, it faults peak at a much eariler time.........untill I set them to 8-9mv...
Tell me where am I doing wrong.............thanks for advance
Old 02-06-2006, 12:34 PM   #9
Default Ice Charger, Smart Tray, Integy 030
I have an Ice Charger and an Integy 30amp discharge tray. My first question is, would it be beneficial to invest in a Novak Smart tray to maintain and condition/equilize my batteries?
2nd, does anyone use the Ice Charger's Step charge feature? Is that beneficial? What does your set-up look like for 3300's and 3800's?
3rd, What would be the best way to charge and maintain these batteries with these 3 products (Ice Charger, Integy 30 amp Discharge, & Novak Smart Tray)?
Thanks for the input...
Madmarti is offline   Reply With Quote
Old 02-06-2006, 03:12 PM   #10
The best way to adjust your delta peak is by temp, start at 0 and work from there,go until you reach 130F degrees at peak this is the optimal temp for 3800's.
Tips on tire maintenance bryanleec Electric Off-Road 16 01-15-2008 07:40 PM
Battery Maintenance chicagokenji Micro and Mini Scales 6 05-03-2007 11:33 PM
Battery Maintenance Equipment 4 Sale!!! RandomFellow R/C Items: For Sale/Trade 10 04-14-2007 09:06 PM
battery maintenance questions PWA Rookie Zone 8 12-25-2005 09:01 AM
Kyosho MP6 Maintenance tips jvannghi Electric Off-Road 2 01-12-2003 06:44 AM
