Old 02-05-2006, 10:48 PM   #1
That0neguy's Avatar
Default Amp conversions
Ok does anyone know how to convert a 10Amp Discharge to a 30 Amp Discharge to find out Acerage voltage?
I have just been deducting .36 off the average voltage (6 cell pack) to get a 30 amps reading......Any help?
Hello.0
That0neguy is offline   Reply With Quote
Old 02-06-2006, 03:41 PM   #2
That0neguy's Avatar
Anyone?
Hello.0
Old 02-06-2006, 04:08 PM   #3
Send a message via ICQ to MattW
I have seen a chart somewhere, but it doesn't really work properly.
The trouble is, different cells actually react differently to teh different loads, depending on their internal resistance.
MattW is offline   Reply With Quote
Old 02-06-2006, 05:29 PM   #4
That0neguy's Avatar
Well there all IB3800s im just looking to see witch of my backs are better.
Hello.0
Old 02-06-2006, 05:37 PM   #5
imjonah's Avatar
Default Hmmm
I do not think it is a linear function. Something like if it takes you 20 secs to run up 2 flights of stairs, it is unlikely you can run up 20 flights of stairs in 200 secs.
or
If it takes 3 carpenters 8 hours to frame a house how long will it take 300 carpenters, the answer is probably not 4.8 minutes.
imjonah is offline   Reply With Quote
Old 02-06-2006, 05:39 PM   #6
SC
SC's Avatar
If you want to see what packs are better simply discharge them and note the voltage @ 30 sec's, 1 min, 2 min, 3 min and 4 min...unless your 8 minute road racing ( however long your race's are just note the voltage in 1 minute increment's till you get to that point )...then just compare your [email protected] only 10 amp's you may want to double the time's above.
SC
SC is offline   Reply With Quote
Old 02-06-2006, 05:58 PM   #7
That0neguy's Avatar
well the charger has a AVG function.So if I could just find a formula to convert it to 30 amps..
Hello.0
Old 02-06-2006, 06:04 PM   #8
ChrisP's Avatar
If you're trying to compare numbers pack to pack, you need to use the same apparatus.
Even if there was a forumla to convert voltages between 10A and 30A discharges (which I don't believe there is) you would still have different tolerances from the readings on the different equipment used.
You cannot cycle your packs at 10A do a conversion and compare the numbers to the pack's 30A labels.
The method described earlier is your best option (using the equipment youhave available to you) to determine which are your best packs
ChrisP is offline   Reply With Quote
Old 02-06-2006, 08:43 PM   #9
asw7576's Avatar
can you borrow turbo gfx from your friend ?
buy muchmore ctx-d !!!!
Old 02-06-2006, 09:11 PM   #10
That0neguy's Avatar
Ahh forget it.Doesnt really matter, Im fast none the less.
Hello.0
X-6 CONVERSIONS NIB $145 pink_sleeve R/C Items: For Sale/Trade 0 09-10-2007 09:44 PM
B3 Conversions TigeRyan Oval, Larger Scales and More 6 01-24-2006 12:23 PM
MFE to MF2 or KE to BK2 conversions? LosiFromHell986 Electric Off-Road 9 05-20-2004 12:33 PM
Kyosho Conversions? BrainTeased Nitro On-Road 46 02-23-2004 04:39 AM
540 Conversions Micro rs4 aznxstyl3z Electric On-Road 2 12-26-2003 04:25 PM
