Carpet tyre structure >
Like Tree1Likes
  • 1 Post By Skiddins
Old 01-08-2018, 07:59 AM
Default Carpet tyre structure
Hi guys, so what are the compound and build differences between carpet and normal on road tyres?
I've seen some with tread patterns, and others that look the same as normal sorex tyres.
I looked at some RUSH tyres, and they state not for asphalt use, what makes this so?
Regards
Stu.
stuartkeith is offline
Old 01-08-2018, 12:46 PM
sosidge's Avatar
I'm not aware of any treaded tyres that have the tread for improved performance on carpet. The tread is for looks and potentially for better grip on wet/dirty surfaces.
The only difference between carpet and asphalt slick tyres is the rubber compound. I am not aware of any tyres that have a unique carpet construction. Usually the pre-mounted carpet tyres will come with a different insert and/or wheel.
sosidge is offline
Old 01-08-2018, 01:05 PM
mschumi101's Avatar
Trader Rating: 30 (100%+)
If they are pre-mounts a main difference may be in wheel stiffness, or the insert. Nothing really changes between the rubber compounds for carpet versus asphalt. Certain compounds will perform better in one environment versus the other.
As far as treads go, this is usually down to a class thing. For instance USGT uses a treaded tire, versus TC uses a slick tire. Check with your local club if there is a spec tire for the class you are looking to run, or a preferred tire and compound for the track.
mschumi101 is offline
Old 01-09-2018, 02:51 AM
Skiddins's Avatar
Regards
Stu.
You'll probably find that the RUSH tyre combination you mention, will make them too soft for asphalt racing so they'll overheat.
Marcos.J likes this.
Skiddins is offline
