Old 02-07-2006, 10:01 PM   #16
R-job's Avatar
Originally Posted by rcguy2477
For the 3800s, you dont want to use a trickle charge, or what you are refering to as a slow charge. After peaking(using a charge rate over 4 amps), the batteries are ready to use. The length of time the batteries last depends on the motor. A stock motor will last around 8-10 minutes and a mod will last from 5-7 under racing conditions.
If your words are right above,then my charger won't even take up to 40mins in a dis-charge/peak charge @5-6A cycle,but then my 3300 packs produce sort of poor punch,i mean they make good punch at start,then drop after 3 mins later,they might have bad cells in between?
R-job is offline   Reply With Quote
Old 02-08-2006, 02:30 AM   #17
IF you have 3300 cells they probently has gone bad how old are they and do you drive tehm often. i have been running my 3300 for a year now and that is way to mutch because i run them about 8 times a week each.
so if your batteries have a low punch you might have whered them out
Rasmus TbEvo IV is offline   Reply With Quote
Old 02-08-2006, 06:33 AM   #18
XrayFK's Avatar
But how many minutes those 3800s can be punched?Sounds like they much better than mine 3300s...
3800 cells are much better than 3300s, lol. With 3800 cells I have punch for an entire race.
XrayFK is offline   Reply With Quote
Old 02-08-2006, 08:43 AM   #19
zipp's Avatar
your motor may be overheating a little. starts off well, but heat builds up causing the loss in punch. just a possible cause..
zipp is offline   Reply With Quote
Old 02-09-2006, 12:22 AM   #20
R-job's Avatar
You may right zipp, i did not notice this til you told here,i use those old stock motors like green can monster 27t,Trinity p2k2t...They're look old though,never replaced bushs or cut...I should try something new like orion evo,but not too sure my batteries can stand it or not?
Old 02-09-2006, 12:27 AM   #21
R-job's Avatar
I don't use my 3300s much,2-4 times per month,especially in this Spring.But i did buy them in used condition.However they look neat&new,but i can't tell they've been over-used or not.I will try to cycle them a few times, hopefully i could wake their punch up back...
Old 02-09-2006, 01:08 AM   #22
zipp's Avatar
sounds like u badly need a motor maintenance then!
Old 02-09-2006, 03:27 AM   #23
off course it can stand the power but if you never cut the amature ore replace the brushes you will not get a puch that is worth anything
Old 02-09-2006, 04:06 PM   #24
R-job's Avatar
Yeah, it think replacing bushes for my motors is the most economy way to see some results lol
Old 02-09-2006, 04:10 PM   #25
R-job's Avatar
But what will a motor be after a "cut" process?Stronger and less overheat risks?I've they've been selling motor cutters alot here.
Old 02-11-2006, 08:32 PM   #26
R-job's Avatar
I Got the meaning.
Some battery questions Motoxpro Electric Off-Road 1 07-28-2007 08:32 PM
Battery Questions... 86Lude20Si Electric On-Road 5 05-02-2006 09:54 PM
Battery Questions pvtysux Electric Off-Road 10 02-17-2005 09:52 PM
Battery questions Rysuleod Electric Off-Road 14 10-12-2004 10:46 AM
Battery questions zachzachz Rookie Zone 2 07-05-2003 03:29 AM
