New FWD M-Chassis from 3 Racing. >
Like Tree35Likes
Old 05-25-2018, 03:13 PM
  #46
tony gray's Avatar
No, no, no....60D's suck. Lots of people make 55mm Mini tires. Sweep, Rush, Pit Shimizu, Volante, all are good.
triguy1975 likes this.
tony gray is offline
Old 05-30-2018, 01:48 PM
  #47
tony gray's Avatar
And Australia is the first country to declare the MG EVO legal to race,
Old 05-30-2018, 06:17 PM
  #48
So I've started my build on this and a couple of comments:
Bag 1 - This is the diff. The gasket isn't made out of paper. It's some vinyl that is a little brittle. The screw holes weren't punched out all the way through for mine so I had to be super careful to get those sorted without ripping the gasket to shreds.
Bag 2 - Build up of the gearbox and motor mount.
Have to be careful with the bearing's here. There are 2 different 10mm OD bearings!
When putting the gearbox and motor mount together, I've noticed that its a bit hard to build completely flat. I'm not at the stage where I need to mount the gearbox and motor mount on to the FRP chassis yet, but I think I'll be careful, undo all the screws holding the motor mount on to the gear box and tighten it all slowly to try and ensure this thing goes together flat.
airbiscuit likes this.
WagwanBumba is offline
Old 06-19-2018, 02:57 PM
  #49
tony gray's Avatar
If you missed out on the initial shipment, the MG EVO will be back in stock at most HK stores by the end of this week.
Scale60 likes this.
Old 06-21-2018, 12:29 PM
  #50
JatoTheRipper's Avatar
Originally Posted by tony gray View Post
This is the shell, new Civic Type R.
p.s. I wont bother to mention that the co-ordinate axis in the bottom l/hand corner is weirdly wrong.
Blame SolidWorks. That's the default coordinate system.
Originally Posted by tvih View Post
Looks nice. It's too bad the Mini classes over here only allow Tamiya Minis. They're such a pain to work on.
I only own the M07, but it's not bad at all.
Awesome! Thanks! I might bite.
JatoTheRipper is offline
Old 07-07-2018, 09:41 PM
  #51
CW22's Avatar
Trader Rating: 94 (100%+)
First time ran the MG Evo chassis, it was a great handling M-chassis car.
Build as a box stock with a 21.5T motor and gear FDR 5.7 to match the other mini on the track.
CW22 is offline
Old 07-08-2018, 08:25 AM
  #52
Suzukee's Avatar
This is one nice little car, just wonder how come there isn't much discussion on it on the web.
Suzukee is offline
Old 07-08-2018, 04:34 PM
  #53
tony gray's Avatar
Because forums and such are dead now. For MG EVO talk, go here
https://www.facebook.com/groups/228887887711385/
Suzukee likes this.
Old 07-09-2018, 09:59 AM
  #54
Airwave's Avatar
forums are dying because people create closed discussion groups... Not the opposite...
G-rem likes this.
Airwave is offline
Old 07-09-2018, 01:51 PM
  #55
tony gray's Avatar
The MG EVO group on FB is a public group, not closed... And I started it because there was so little chat on here, but the FB group is going along nicely.
Old 07-09-2018, 02:14 PM
  #56
CW22's Avatar
Hey Toni, what lenght are you using for your mg evo.
CW22 is offline
Old 07-09-2018, 02:35 PM
  #57
tony gray's Avatar
Have only run it as supplied to us which was MWB.
Old 07-09-2018, 02:38 PM
  #58
CW22's Avatar
i ran mwb too last saturday, i might try LWB this week.
CW22 is offline
Old 07-10-2018, 09:04 AM
  #59
Suzukee's Avatar
How far are everyone deviating from the stock setup? Like shock oil, pistons, springs, roll center, etc.?
Although good out of the box, it can be better I'm sure.
500,000 diff oil could be too heavy for some conditions.
And having a mix of shock springs could be better than running all 4 springs with the same rate?
Stuffs like that....
Suzukee is offline
Old 07-11-2018, 02:07 PM
  #60
tony gray's Avatar
We havent done anything yet, we cant race the cars here until Oct 8th.
