Capricorn P12 1/12 pan car >
Like Tree11Likes
Old 12-28-2017, 09:31 PM
Default Capricorn P12 1/12 pan car
Anyone running this chassis?
Can't find much info about it.
Love these features:
1. Sliding ride height adjustment.
2. O-ring battery hold down.
3. Easy battery position adjustment.
4. Big center shock, and looks easy to adjust shock lengths.
5. Looks beautiful~
If you are running this chassis, please post your thoughts and pictures.
Thank you.
Ted Su(TW) is offline
Old 12-28-2017, 09:42 PM
Pinkz's Avatar
1/12 forum has a wiki at front of most common 1/12th on road pan cars
LAB P12 PAN CAR 1/12 ? CapricornRC has some various photos in that link below.
Lab P12 manual rel. 1.2 ? CapricornRC
car is rather new, appears below has them now, prior to that you would have had to order direct from italy
US or NA distributor is Capricorn Lab P12 1/12 Pan Car
Ted Su(TW) likes this.
Pinkz is offline
Old 12-29-2017, 03:43 PM
Is that an Associated front end?
DavidNERODease is offline
Old 12-30-2017, 04:42 AM
Looks like a CRC rear pod and Associated front end. Upper arms look beefier though which is nice.
Robbob is offline
Old 12-30-2017, 10:15 AM
Trader Rating: 24 (100%+)
its an xenon front end parts are interchangeable between r5 based front ends. rear pod is their own.
Scirocco is offline
Old 12-30-2017, 10:22 AM
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
Guess they forgot the upper arm caster shims / clips.
1/8 IC Fan is offline
Old 12-30-2017, 02:42 PM
chris moore's Avatar
Trader Rating: 96 (99%+)
Kind of a bit of everything with their own carbon parts, AE frontend not Xenon. Xenon lower arms are not curved and are flat on top, these have the ridge and are curved so AE for sure. Serpent body posts, servo mounts look like ones used by Hyperdrive and a few other kits. Not sure on the slider rear pod as I don't have any CRC cars currently.
chris moore is offline
Old 12-31-2017, 12:59 AM
fast-ho-cars's Avatar
just built a CRC CK25 for a racer at our track, slider pod is not same as CRC other than maybe red anodizing. some like RSD, Corally, and some conversions like Zen have slider pods of variated designs. looking at manual, appears pod pivot system is like the Serpent car.
fast-ho-cars is offline
Old 12-31-2017, 03:12 AM
Flygio's Avatar
The real pod is actually pretty smart...it's a slide type but with shims and a screw in the upper side... So you can easily set the ride height equally l&r and or won't shift under impacts. A nice evolution or the CRC concept in my opinion
Flygio is offline
Old 12-31-2017, 06:43 AM
Yes, the rear pod design looks quite racer friendly.
Old 12-31-2017, 02:33 PM
thisguy2849's Avatar
I ran mine for the first time yesterday with the new aluminum chassis on high bite black carpet. Car is a bit of a mix between serpent and top. The rear pod is very easy to set and adjust.
Ted Su(TW) and two shoes like this.
thisguy2849 is offline
Old 01-01-2018, 07:02 AM
Will you mind posting some pictures of your ride please?
What do you think about the plastics (front arms for example), are they firm or soft?
Where did you get your kit and the aluminum chassis from?
Sorry for the multiple questions. I'm very interested in one, but can't find any "real" info about this kit other than the manufacturer's descriptions and official pictures.
Thank you.
Old 01-01-2018, 07:31 AM
Rctarget.com is the distributor in north america for Capricorn. Arms are a medium/hardish plastic. More than firm enough for black carpet racing. First picture is of a friends car with the carbon chassis
Attached Thumbnails Capricorn P12 1/12 pan car-received_10210712448835966.jpeg   Capricorn P12 1/12 pan car-20171225_162127.jpg   Capricorn P12 1/12 pan car-received_2173770555970151.jpeg
Buckland and Ted Su(TW) like this.
Old 01-01-2018, 10:23 AM
Thank you.
car is a recent release. many top drivers are snapped up by bigger or more well established 1/12th car companies. this results in high quality 12th cars receiving very little attention, comments, etc. looking at 12th scale wiki you see this with 10-13 brands of 12th cars
21 Dec 2017, new products Capricorn P12 Aluminium Chassis & TE-03 Upper Deck | RCNews.net - RC Car News
Oct 17, 2017, The new Lab P12 1/12th Pan Car is ready LAB P12 PAN CAR 1/12 ? CapricornRC
Aug 9, 2017 car was announced https://www.bigsquidrc.com/capricorn-c-12p-pan-car/
Old 01-04-2018, 12:10 AM
I'm about to place an order. What spare parts will you recommend?
