FDR
Can any one tell me, if wanted a FDR of 7.93 what is the better way to get it. A spur of 61t and piņon of 20 or spur of 58 and pinion of 19. They both will do a FDR of 7.93 is one way better than the other.
Cheers |
No difference in speed but there will be a slight shift of weight form the motor depending on what you choose.
True. Only difference will be motor position - and therefore weight distribution. But we are talking about small differences here - in this case here, assuming we're talking about 48dp, the motor would move ~1.1mm.
The maximum change I can reach in motor positions, while staying with the about the same gearing on my T4'17, is ~3.5mm (calculated for a target FDR of 5.0, or closest possible, without ever going any lower (so no 4.999s), the combinations with the max. distance in 64dp are 37/98 and 42/111, with actual FDR varying from 5.021 to 5.032, between those extremes, while the in-between 38/100 will hit a perfect 5.000 spot on). |
Fdr is fdr, use the best combination for your particular car
You may get slightly better wear using the larger pinion.
Cheers, Jim |
Originally Posted by DirkW
(Post 15099904)
True. Only difference will be motor position - .
