RaceOpt MTS 1/10 Electric FFV3 Pro Car Kit >
Like Tree112Likes
Old 01-14-2018, 12:08 AM
  #136
G-rem's Avatar
I can't properly figure out as per pictures or manual how to setup the rear toe? Can someone explain me how it works? Thanks!
G-rem is offline
Old 01-14-2018, 12:25 AM
  #137
ErikJan's Avatar
Originally Posted by Marcos.J View Post
So I replaced the stock screw with a slightly longer screw about 13.1mm long.
Good point! I also checked the scews last week, because the 1.5mm Hex went a bit round, but left it for the moment.
This is a good moment to switch to some high quality 2.5*14mm torx.
ErikJan is offline
Old 01-14-2018, 12:31 AM
  #138
ErikJan's Avatar
Very simple. There are 3 holes on the carbon part and 3 on the alu part, just a bit offline. When using the mid position you have 2.0 toe, when using the outsider hole the toe is 2.5. I checked on the set up board, and it is very accurate.
Marcos.J and G-rem like this.
ErikJan is offline
Old 01-14-2018, 12:56 AM
  #139
G-rem's Avatar
Thanks Erik!
G-rem is offline
Old 01-15-2018, 10:26 AM
  #140
Tech Legend
Marcos.J's Avatar
Trader Rating: 192 (100%+)
the stock screws are 11mm in length adding the extra 2mm will give it a little more strength. I ran them all saturday night in practice and all day on sunday with no issues what so ever even after taking a few hard hits lol.
Marcos.J is offline
Old 01-16-2018, 02:07 AM
  #141
ErikJan's Avatar
As I have 3x14mm Stainless steel screws available, I careful tapped the steering block from the 2.5mm hole to M3. Feels very solid. 14mm is just long enough.
Will try next weekend, although it is not the idea to do a real strength test and hit something.
Marcos.J and Bartolo Racing like this.
ErikJan is offline
Old 01-16-2018, 04:24 AM
  #142
Tech Legend
Marcos.J's Avatar
at 14mm make sure the front axles move freely
Marcos.J is offline
Old 01-16-2018, 07:08 PM
  #143
Tech Legend
Marcos.J's Avatar
Got the 3Racing front and rear(1deg) aluminum hubs installed on my MTs/V3 prototype , this will Work on the FFv3 and it should make it a lot stronger if not bullet proof . Using 3mm front hexes for proper track width.
Marcos.J is offline
Old 01-18-2018, 02:12 PM
  #144
Tech Legend
Marcos.J's Avatar
With the aluminum front hubs and a 3mm hexes the width is just about 1mm wider than stock .(The aluminum front hubs make the car a little wider so I had to replace the 5mm hex with 3mm)
The MTS-V3 with the White bomber ready for this weekend’s 17.5 invitational at Valkaria Florida
Bartolo Racing likes this.
Marcos.J is offline
Old 01-20-2018, 09:08 PM
  #145
Marcos
Could you please post a link to the 3 racing aluminum hubs? I tried out the car today and it was amazing except I broke the front right hub.
Kahmed79 is offline
Old 01-20-2018, 09:30 PM
  #146
Tech Legend
Marcos.J's Avatar
Originally Posted by Kahmed79 View Post
Marcos
I got them on amazon.com also if you replace the stock screw with a13mm screw it wll make it a little stronger
Marcos.J is offline
Old 01-21-2018, 09:47 AM
  #147
Bartolo Racing's Avatar
Got them
Attached Thumbnails RaceOpt MTS 1/10 Electric FFV3 Pro Car Kit-26169813_1568963683139241_2990422441919157307_n.jpg
Marcos.J likes this.
Bartolo Racing is offline
Old 01-22-2018, 07:08 AM
  #148
I thinking I'm going with aluminum blocks this time. The barrier at my track is too good at destroying the plastic ones.
Kahmed79 is offline
Old 01-22-2018, 08:25 AM
  #149
Tech Legend
Marcos.J's Avatar
dont hit it then
Kahmed79 likes this.
Marcos.J is offline
Old 01-22-2018, 08:44 AM
  #150
dont hit it then
Yes that would be ideal!
Kahmed79 is offline
