Like Tree1Likes
  • 1 Post By TryHard
Old 12-03-2017, 11:34 PM   #1
Nuno Gancho's Avatar
Default Sanwa PGS-LH Installation
Hello anyone know how we should install and set the servo to enable the SSL mode for touring car.
What até default value of settings.
Is there video how to install and change settings.
Nuno Gancho is offline   Reply With Quote
Old 12-04-2017, 02:02 AM   #2
You enable SSL mode from your TX in the bind menu within system.
To program the servo, you either get the program card or there are some parameters you can program with your TX after plugging the servo in to CH 4 or AUX. Can't remember which one
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P12 & F1 / Schumacher Mi6Evo / Awesomatix A800 / Xpress XQ1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
WagwanBumba is offline   Reply With Quote
Old 12-04-2017, 02:06 PM   #3
Airwave's Avatar
Don't forget, when you change the mode on a channel you have to rebind your receiver, or the change is not applied.
Airwave is offline   Reply With Quote
Old 12-04-2017, 03:50 PM   #4
Thanks all, after changing servo settings do right away the re-bind or turn off then ré-bind their receiver.
Anyone that may help with what is default settings and how to change.
Old 12-05-2017, 08:30 AM   #5
Everything should be on the same bind screen. Toggling the servo mode does nothing.
moistAF is offline   Reply With Quote
Old 12-05-2017, 09:35 PM   #6
dan_vector's Avatar
Trader Rating: 27 (100%+)
Make the setting changes on the Tx then switch on the Rx and immediately re-bind. You don't need to power cycle the Tx.
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 12-06-2017, 07:10 PM   #7
Where to change settings in TX
By then end still in Fh4t and SHR mode correct thanks
Old 12-07-2017, 12:10 AM   #8
dan_vector's Avatar
No SSR. It's under the BIND menu.
Old 12-08-2017, 01:47 AM   #9
TryHard's Avatar
Actually, if you plug the servo into the SSL port on the RX, its already working in SSL mode with the transmitter... But unlocking the rest of the features requires a bit of work
Ok, so if you want telemetry, you'll need to activate it in the BIND menu (SYSTEM - BIND - TELEMETRY to ON).
Next, if you want to activate the programability, you need Racing Mode engaged, and the Aux2Code10 option active.
[1 - Telemetry]
First, turn on the Aux Code 2. In the SYSTEM menu, find the AUX TYPE sub menu. Here, go to AUX2 selection, and set to CODE10.
[2 - AuxCode]
Now sort our the Racing Modes. Go to RACING, then R-MODE (which if you use steering expo, should need to be on already). Turn it from INH to 2, 3, 4 or 5 (the numbers give you more modes. 2 gives you R1, R2. 3 gives R1, R2 and R3, etc.)
[3 - R-Mode]
Whilst in the R-Mode screen, scroll to the bottom and turn on CodeAX2 to ON. (You'll need to do this for each R-Mode too), along with any other options you want.
[4 - R-Mode AuxCodeON]
With all that done, to program the servo... go back into the RACING menu, Select C-AUX2, and bingo, changing the values of CODE-1 through CODE-7, you can tune the servo (I've relabelled them on my Tx to represent the settings.. see image).
[5 - AuxCode Setting]
Repeat the setup for each R-MODE.. and here's the beauty. By using different R-MODES, with different Aux2Code10 settings, you can tune the servo to switch quickly mid race. For example... R-MODE 1 could be a high grip setup, R-MODE 2 lower. Flick between the R-Modes, and you can instantly change the feel.
Oh and to setup the R-Mode switch... go to SYSTEM and ASSIGN.. then pick a switch or Trim lever (I have mine on Trim3)
Links to the suggested setting sheets from Sanwa;
Default settings by class - http://sanwa-denshi.com/rc/news/PGS-...20Category.pdf
Team Driver settings - http://sanwa-denshi.com/rc/news/Sett...%20Drivers.pdf
Only thing to note is that to get the full tuning, you still need the PGS setting box...
Sanwa PGS-LH Installation-1-telemetry.jpg   Sanwa PGS-LH Installation-2-auxcode.jpg   Sanwa PGS-LH Installation-3-r-mode.jpg   Sanwa PGS-LH Installation-4-r-mode-auxcode-.jpg   Sanwa PGS-LH Installation-5-auxcode-setting.jpg
nnick likes this.
| THard.co.uk | MugenSeiki | MMI | MuchMore |
Old 12-08-2017, 02:05 AM   #10
dan_vector's Avatar
[1 - Telemetry]
[2 - AuxCode]
[3 - R-Mode]
That’s all true and great help but just to point out you can only program the servo on a compatible SSL radio with Code 10 such as M12S, Exzes ZZ, MT-44. You can’t use Code 5 on these servos on radios M12, Exzes Z, MT-4s. So make sure you are using a compatible Tx!
Old 12-11-2017, 08:07 PM   #11
Excellent will try thanks
Old 01-25-2018, 11:13 PM   #12
Indeed great help
Have in minde the code names have been changed example from code01 to SSL in the photos
Would like to know if to be able to program we need to have the 482 receiver or 481 will do
Why have same drivers use EP Buggy default settings on TC car
if we don’t have aux2 ON at the racing mode what will be the servo default settings
If we have the servo on CH1 what will be the default settings
To be able to change settings the servo must be connected to the SSL/BAT port of the receiver correct
