Amperage Question >
Amperage Question
Like Tree4Likes
Amperage Question
Old 11-28-2017, 09:56 PM
Dobbs's Avatar
Trader Rating: 30 (100%+)
Default Amperage Question
Question for the electric whizkids out there.
My F1 car with a ratio of 2.97FDR, 63mm diameter tires, trinity d4 25.5, and 4600mah 90c 2s Lipo on a fully charged (8.4v) pack draws 10.92watts @ 1.3amps.
Now with that data, my battery has the potential to put out a maximum of 414 amps if I take 4.6 amps multiplied by 90 as a discharge rate if I am understanding this correctly.
My VTA car with similar data was pulling the same wattage of 10.92 from an MC1 motiv 25.5 with a 65c 5000mah battery and 3.93FDR and 65mm tires.
Given these same outputs of wattage is it safe to assume that the maximum amp draw from any given 25.5 motor is going to peak at around 1.3 amps?
I would have thought the added resistance and weight of a 4 wheel drive train plus the difference in gearing would result in more of an amp draw ergo meaning I need more power to propel the VTA car.
Does this sound correct?
Dobbs is offline
Old 11-28-2017, 10:23 PM
gigaplex's Avatar
That 1.3A draw sounds like the unloaded steady state current draw. It'll draw a lot more than that while under load while accelerating. How are you measuring the current?
The C ratings on batteries are more of a guideline, they aren't well defined. The solder on the internal wiring would probably melt before you actually hit 414 amps.
gigaplex is offline
R3VoLuTiOn's Avatar
Trader Rating: 29 (100%+)
how are you measuring the current draw?
I'm certain under load it would be MUCH higher.
R3VoLuTiOn is offline
Old 11-28-2017, 11:00 PM
Dobbs's Avatar
I had my PA 0101 wattmeter setup and was pulling full throttle at time of recording data.
I used this meter for electric airplane setups to determine wattage for motor systems. I figured I could use it to check wattages and amp draw on the cars too
Dobbs is offline
Old 11-29-2017, 12:19 AM
gigaplex's Avatar
Were you driving it or was this on the bench with the wheels off the ground? If the latter, thats not representative of actual use. I'd expect peak currents of at least 20 amps, if not a lot higher.
gigaplex is offline
Old 11-29-2017, 05:08 AM
Dobbs's Avatar
It was on bench, wheels up. I will be testing at the track later today so maybe I can put the car down on the burnout pad and get a better reading with more rolling resistance.
Dobbs is offline
Old 11-29-2017, 06:57 AM
LJH
Running the car off the ground would be like testing a plane motor without a prop. I also fly a lot of e-powered planes and was curious of the amp draw of my cars so to get the average amp draw for a run on my 17.5 turn TC I used the Mah used vs. the time run and it averages right around 15A. Obviously the amps while accelerating are much higher.
Cheers,
Jim
LJH is offline
Old 11-29-2017, 01:13 PM
Dobbs's Avatar
Cheers,
Jim
Yeah I never thought about the resistance aspect of the friction from the wheels on the ground much like a prop biting into the air resistance from an airplane motor spinning.
Dobbs is offline
Old 11-29-2017, 02:49 PM
gigaplex's Avatar
It's not the friction that adds all the load. Physically moving the mass of the car is where most of the energy goes.
Tim Neja likes this.
gigaplex is offline
Old 11-29-2017, 06:47 PM
Dobbs's Avatar
So after testing we were pulling between 15-18 amps at full throttle with 130-150 watts.
Dobbs is offline
Old 11-29-2017, 07:10 PM
gigaplex's Avatar
Yep, that sounds more realistic.
gigaplex is offline
Old 11-30-2017, 07:34 PM
MaxRain's Avatar
I built a Dyno and found that a 21.5 T can draw 25-30 amps easily under load
MaxRain is offline
Old 12-01-2017, 06:32 AM
howardcano's Avatar
Trader Rating: 37 (100%+)
The latest ROAR-legal 21.5T motors will draw over 140 amperes peak from a standing start if the battery can handle it.
howardcano is offline
Old 12-01-2017, 04:00 PM
Skiddins's Avatar
Are you sure about that?
That's over 1.1KW at 8V
21.5's tend to be rated at a couple of hundred Watts, the 25-30A (whilst accelerating etc) sounds far more reasonable.
I can wheelspin a TC off the line with a 13.5
My F1 (21.5) just pulls away without any drama even if the throttle is buried (Taking 1200mAh out during a run equates to an average of 14A)
Skiddins is offline
Old 12-01-2017, 04:05 PM
Adamska27's Avatar
https://www.teamassociated.com/pdf/c...Spec-Chart.pdf
I hope this helps
Adamska27 is offline
