New Gravity Foam spec tire
#136
Sandbagging will always happen. There should be a class for them called Open Whining.
If mod foam sedan happens, it will bring back some of the old guys. If people get it out of their head that mod is a 4.5 motor, it might help the perception of what is intended by running a hard spec foam tire. I'm waiting for someone to figure this all out, slap in a 13.5 or 10.5 and proves the point by kicking absolutely everyone's ass.
The track is a bit bigger now so I typically run a mild setup on a 4.5t motor.
#138
Now you are splitting classes... Stock performs just fine on rubber tires. Mod is on the limit so foam tires make sense.
Stock is highly regulated and foams will be very hard to regulate from many perspectives. Sure it would be easier to drive and I'll bet a lot of fun but it's stock.
You just said it , It would be easier to drive and a lot of fun thats what stock Should be.
If you opened up the the stock rules to use foam . it would take over.
If you are talking of spliting classes , Classes evolve ( or devolve)
#139
#140
I dont Think that One persons ideals should limit what other people may want to do.
#142
Yesterday had usually warm morning, 50’s. Here are the foam and the USGT Tires back to back on the 4x
https://youtu.be/DgRJl-wqU7c
#143
#146
Why does everyone want to ditch rubber when the cars are finally optimized for it? Foam was ditched was left long ago because the rest of the World didn't and still doesn't run it. This is why you don't see many top American onroad racers anymore, they became obsolete when rubber hit.
