Like Tree3Likes
  • 2 Post By trigger
  • 1 Post By gigaplex
Old 11-24-2017, 07:18 PM   #1
Bob Corey's Avatar
Default Adjustable rear toe modification?
Hello, I need to have the rear toe adjustable because my HPI Sprint 2 tends to have unpredictable random steering. It runs like a boat because the too much inward toe makes the rear end "float" because each side tries to push the car to the center.
Anyway after a testing I found out that the solution to my problem is to have zero toe on my wheels. On the internet I have seen some guys have adjustable rear toe but the Sprint 2 doesn't.
So I need to figure out how to adjust it maybe putting parts like the front wheels but without the servo. If you have any STL files to 3D print the rear suspension arms a little differently, would solve the problem too!
If you know how to do this mod please tell me
Bob Corey is offline   Reply With Quote
Old 11-24-2017, 08:17 PM   #2
Starting a second thread about your car isn't necessary.
JoshuaRC10 and Bob Corey like this.
Minh Nguyen
[Maclan Racing] [Xpert Servos]
trigger is offline   Reply With Quote
Old 11-24-2017, 10:22 PM   #3
LJH
Pretty much every chassis with IRS has some amount of rear toe-in, without it the car will be very unstable at speed
Cheers,
Jim
LJH is offline   Reply With Quote
Old 11-24-2017, 10:58 PM   #4
snuvet75's Avatar
Trader Rating: 16 (94%+)
More than likely, your steering issue is not because of rear toe. If any, it makes the car stable. It must be set at 3 degree toe in. I heard that Sprint has quite a wobble in the front wheels and it does not center well. You may want to check your servo to see if it has enough torque. It might help if you describe what you meant by unpredictable steering.
Capricorn LAB C03, Capricorn LAB C803, Serpent Project 4X, Serpent Spyder SRX2, Mugen MTC-1
RCTarget, DeSotoRacing
snuvet75 is online now   Reply With Quote
Old 11-24-2017, 11:02 PM   #5
How many degrees toe does it have now?
belewis01 is offline   Reply With Quote
Old 11-24-2017, 11:51 PM   #6
gigaplex's Avatar
They've got more info and some videos in the other thread on this same issue.
snuvet75 likes this.
gigaplex is offline   Reply With Quote
Old 11-25-2017, 01:58 AM   #7
Roelof's Avatar
Send a message via ICQ to Roelof
Again, the video's you showed have nothing to do with the setup of the car but more with the play or electronics.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 11-25-2017, 05:38 AM   #8
Bob Corey's Avatar
Guys thanx for all the replies, but it's not the electronics or the servo, or the floppiness of the steering system, I am saying this for sure because the exact same thing was happening when I DISCONNECTED the servo and locked in place the front wheels with wires so they stay dead straight. After some testing making the rear toe much less, the car finally started going straight without unpredictable course changes. In theory you must be right (maybe for a heavier car) but I really couldn't go straight before decreasing the toe!
Don't know how many degrees toe is this but this is the before and after:
Here's the original thread I opened, has some videos in there too. I opened this thread because I thought was a different subject looking for a mod for adjustable rear toe.
http://www.rctech.net/forum/electric...l#post15086765
Kyosho Ultima RB6 & RB6.6 Car Thread Cpt.America Electric Off-Road 14662 02-18-2018 09:48 PM
Introducing the Kyosho RT6! Kraig Electric Off-Road 1107 01-20-2018 06:54 AM
Camber Adjustment. Need some expert advice! :D Siddyboy Electric On-Road 11 04-13-2014 05:56 AM
TC3 Modifications that make a difference Cain Electric On-Road 21 03-26-2004 06:05 PM
Tags
adjust rear toe, hpi sprint 2, rear toe, rear toe mod
