Like Tree10Likes
TC 1/10 servo
Old 11-21-2017, 11:01 PM
Nuno Gancho's Avatar
Default TC 1/10 servo
Hi all, would like to have same suggestion on current best servo for TC. Should I go for latest sanwa SSL or try other brands, meantime I am using sanwa M12. Thanks
Nuno Gancho is offline
Old 11-22-2017, 03:43 AM
massenb203's Avatar
Savox 1251-MG Black Edition.
mracer1 likes this.
massenb203 is offline
Old 11-22-2017, 04:15 AM
Set
sanwa PGS
jlfx car audio likes this.
Set is offline
Old 11-22-2017, 06:42 AM
Trader Rating: 38 (100%+)
Spektrum S6270.
Jamie Hanson is offline
Old 11-22-2017, 07:41 AM
Sanwa PGS-LH - without a doubt
WagwanBumba is offline
Old 11-22-2017, 07:56 AM
Trader Rating: 36 (100%+)
I am running a Futaba bls451, because that is what I had. I don't know what all the fuss is about with the low pro servos. Generally if I want to balance my car I have to add weight to the electronics side anyway, so might as well put a heavier servo there to begin with.
trilerian is offline
Old 11-22-2017, 07:58 AM
Ivan Dickson's Avatar
Trader Rating: 32 (94%+)
Sanwa radio = Sanwa servos, you can't go wrong, their are many good servos on
the market...the final choice is up to you.
jlfx car audio and silden like this.
Ivan Dickson is offline
Old 11-22-2017, 09:59 AM
Airwave's Avatar
Highest RC, without any doubt.
Bar, alecladanga and mikeygar like this.
Airwave is offline
Old 11-22-2017, 02:20 PM
What's the benefit of the sanwa pgs vs ers-971 that is 1/3 of the cost? Torque?
rcja is offline
Old 11-22-2017, 02:53 PM
Is Savox water prove looks like.
Yes since I use sanwa radio maybe go for PGS but what will that give me more compared with previous models if u will not program it and it is quite more expensive meantime what do we need to program it, thanks
Old 11-22-2017, 03:22 PM
gigaplex's Avatar
When you ask what's the best servo, you're going to get suggestions that are overpriced. What's your budget? Do you really need the best? Servos get into diminishing returns territory very quickly.
gigaplex is offline
Old 11-22-2017, 05:14 PM
Never tried the ERS 971
But amongst all the servos I've tried (Savox, KO, Xpert, PowerHD, Highest) the PGS-LH has amazing center hold and is super precise. It's not the fastest servo I own but I doubt anyone will notice the ever slightly slower on the bench speed but will appreciate the on-track feel and response.
I have been really tempted to switch all the cars I run regularly over to the PGS-LH ... it's that good.
Old 11-22-2017, 10:37 PM
alecladanga's Avatar
I use the SANWA M12S and Im using the PI-3431 high speed and high torque servo. cheaper than the sanwa servo but performs the same.
I even use it in SSR mode. Xpert made this servo to match with Sanwa's SSR mode (got confirmation of this from the xpert mechanic in Asia).
Check the link below xpert-rc PI-3431
alecladanga is offline
Old 11-23-2017, 01:23 AM
Originally Posted by alecladanga View Post
I use the SANWA M12S and Im using the PI-3431 high speed and high torque motor. cheaper than the sanwa servo but performs the same.
Agreed the Xpert servos are awesome. My next choice after the PGS-LH. I have a few of the PI3402 servos and they're pretty great!
alecladanga likes this.
Old 04-24-2018, 03:44 AM
You run with SSR mode or normal mode?
NePTuS is offline
