Like Tree1Likes
  • 1 Post By SteveM
Old 11-15-2017, 04:30 AM   #1
Default Schumacher MI1v2 Gear ratio help
Hi
Just playing around with a Schumacher MI1v2 for my wet car on tarmac. Can any one throw me a good starting point for gear ratio. I am running 17.5 blinky.
Either FDR or MM per rev? Any help would be great thanks :-)
mjdennison is offline   Reply With Quote
Old 11-15-2017, 06:14 AM   #2
SteveM's Avatar
Trader Rating: 142 (100%+)
I always start with an FDR of 4.00 and adjust up or down depending on track size. Sounds like you'll be outdoors and the track will likely have a nice long straight, so perhaps something around 3.80 or lower might work. Always check temps and if too high then gear down slightly and try again after everything cools off.
mjdennison likes this.
SteveM is offline   Reply With Quote
Old 11-15-2017, 07:17 AM   #3
Cheers, just the help I needed :-)
