Which F1 for 2018?
#152
I had an Exotek IFS front on my Streetjam and with the batteries mounted sideways, it handled pretty damn good on asphalt and had smoother transitions than a link car.
It was finicky to setup though and not as durable.
#153
Thanks for link and photo, should we have any type of grease on the center pivot ball on the associated one or even on the xray original one thanks
#155
Thanks.
Testes the new Montech front wing much better feeling on the front compared with the old Montech wing
#156
The original Zen racing version used the Xray kits original pivot ball and after a couple of runs had a perfect fit.
The Associated is tighter.
#157
This is very interesting!
http://www.teamspeedmerchant.com/gra...ne-2018-01.jpg
TeamSpeedMerchant.com, High Performance R/C Cars and Accessories! scroll down to see info on the Speedmerchant F1!
http://www.teamspeedmerchant.com/gra...One2018-02.jpg
#159
Montech wings
I’m not loving the new wing. Seems like they bend really easy. Kinda like the wide Tamiya. I always boiled the original Montech and it was super durable. Maybe boiling the new one is a bad idea? Like the new Montech rear. Gives 3 height positions for the upper wing.
#160
#161
If you look at the AE pivot from the F6 instruction manual, you could see the "bridge" is a solid aluminum piece that does not need to be adjusted. A smooth, plastic rounded insert goes under the bridge. There is no binding when the pod is rotated left and right. And can move back and forth smoothly when the center shock is compressed or uncompressed. A very nice setup to mitigate tweak.
Can't go wrong with the three for asphalt. I've raced both the Roche and Xray and they handle very similar.
#163
Edmund, for Norcal Hobbies, 571/572, TCS, CRC tires are still fastest.
#165
New xray's come out in oct usually, why not wait?
