Which F1 for 2018? >
Which F1 for 2018?
Like Tree56Likes
Which F1 for 2018?
Old 01-30-2018, 09:14 AM
  #106
cpal's Avatar
thanks
cpal is offline
Old 01-30-2018, 09:33 AM
  #107
cpal's Avatar
any body have tight pivot balls in upper arms?
cpal is offline
Old 01-31-2018, 08:05 AM
  #108
Have to add the new Tamiya TRF103 to the list. It looks fantastic. Massive improvement.
DavidNERODease is offline
Old 02-01-2018, 09:54 PM
  #109
likea45's Avatar
Anyone have any feedback on the Yokomo YR-10? I’m a kyo driver but we haven’t had a car in a long time so next best think is yoke. Chassis looks much like the rest. Track is grey carpet with foams.
likea45 is offline
Old 02-01-2018, 11:28 PM
  #110
Ph3nyx's Avatar
The car needs a lot of work to be dialed in . the front is more agressive then the other F1 on the market , so you'll have to calm it down , and this will affect the overall performance. the front ride height is limited (max 4.5mm)
Otherwise the chassis is very strong and durable, but i won't recommand it for a beginner in that category.
if i were you, i'll take a look at xray, serpent , shepherd, roche or VBC instead.
Ph3nyx is offline
Old 02-04-2018, 09:22 PM
  #111
likea45's Avatar
Thatís odd as most setup sheets point to 4mm by adding a shim to the top of the arm. It won snowbirds in 2017 I believe.
likea45 is offline
Old 02-04-2018, 09:59 PM
  #112
Default YR10F
I have always been partial to Yokomo, so I bought a YR10F when I got into F1. After struggling with it for about a year, I finally abandoned it and bought a 2018 X1 and it's incredible how much better it feels. I have no carpet experience though, only asphalt. Oh, another issue with the YR10F is that it's very hard to get it down to the 1050 weight. It's a heavy kit, even with Ti screws.
XtremelySLOW is offline
Old 02-05-2018, 02:15 PM
  #113
You can also consider the Serpent F110 SF3. We run it very successful at ETS.
It's lightweight, easy to build and fast.
Check the narrow chassis in combination with the "transversal style weight distribution".
Note: as designer I am biased ;-)
DavidNERODease likes this.
David_E is offline
Old 02-05-2018, 02:37 PM
  #114
sbd
Yes, I can confirm the serpent is a great car on carpet. It is not straightforward to get parts though.
sbd is offline
Old 02-05-2018, 04:08 PM
  #115
I nearly clicked "buy" on the Serpent F110 SF3 a little while go. I've held back because I have too many brands on the go. It's kind of stressful once you start to get more serious about racing... so many different characteristics and different parts to stock etc. I have had a grand old time in the last few years trying different brands and now I feel like I need to make a colour choice and stick to it. Arg, dull but astute.
Old 02-06-2018, 06:51 PM
  #116
idbdoug's Avatar
Trader Rating: 39 (100%+)
What parts are u having a hard time getting?. Been racing SF3 since it’s came out and I’ve only broken 1 upper arm
idbdoug
idbdoug is offline
Old 02-06-2018, 08:38 PM
  #117
A very simple fact to choosing what F1 to get. How easy is it to get PARTS where you are? You can have the best car out there and if you break something it becomes and instant shelf queen until the parts eventually show up.
BullFrog is offline
Old 02-08-2018, 07:54 AM
  #118
Originally Posted by likea45 View Post
Anyone have any feedback on the Yokomo YR-10? Iím a kyo driver but we havenít had a car in a long time so next best think is yoke. Chassis looks much like the rest. Track is grey carpet with foams.
I have a yr-10f. After 2 years of tuning and fitting Xray parts, AE parts, Tamiya parts and homemade parts the car is finally competitive. I would not recommend it to anyone.
pat5b likes this.
rezin is offline
Old 02-08-2018, 12:12 PM
  #119
Haha, yep! Same here... CRC left rear hub, Xray thrust bearing and cone washers, Associated front lower arm mounts, Serpent wings (wide type.)
...Still a lap down to the guys running X1 cars.
Old 02-09-2018, 07:42 PM
  #120
Tim Neja's Avatar
I just picked up a beautiful Exotek from a nice gentleman in Europe. Looking forward to playing with the front end as it's got LOT'S of adjustability for steering!! Should be FUN to figure out!!
Tim Neja is offline
