HPI - steering problem - servo upgrade help
Hello, I've been upgrading my HPI Sport 2 Sprint trying to make it go straight, there was some floppiness on the steering system, I upgraded the front ball cups now it feels pretty steady but still steers so I finally spotted the problem:
The front servo is not powerful enough to keep the steering system straight, so after the turns it doesn't return to dead center so it keeps having a curved course. Also in case there's little force on the road (little rock, bump or sth) it again steers on its own making it super hard to drive especially in tighter situations. After some tests even lifted in the air I'm pretty convinced it's the stock servo. I looked on ebay and youtube and there are some good ones but pretty expensive (around 50$) can you suggest a budget solution? If there's one... For e.g. is this worth it or I have to go with the expensive ones? Any experiences? ebay.com/itm/Core-RC-9016MG-Servo-9Kg-16-Sec-CR494/371847535431?epid=1941984865&hash=item5693d71b47:g :wnEAAOSw241Yh2zV Waiting for your comments. Thank you :-) |
Hard to say without knowing what is currently installed, but I would look at something like the Savox 1251MG ( and $50 is not an expensive servo to most BTW ). If you really want to go with a less expensive servo - copy the dimensions and torque specs of the Savox.
I would avoid super cheap ..... after all, isn't that what you have now? |
Originally Posted by belewis01
(Post 15073825)
I would avoid super cheap ..... after all, isn't that what you have now? I must say that I don't quite understand the specs and what the numbers mean except from the dimentions and delay time. It's cheap but branded (cheap & branded usually means bad quality - higher life). Even on this cheap servo the kg/cm torque seems much higher than my stock and(!!!) the 50$ savox servos Cheap: ebay.com/itm/Power-HD-4-8-6-6V-Super-Torque-Digital-Servo-Crawler-Buggy-1-10-RC-Car-LF-20MG/311773799105?epid=509801116&hash=item48972aa2c1:g: 21cAAOSwHsRYDaAI Savox: vi.vipr.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=131567247601&t=1 497235778000&tid=10&category=56615&seller=rcmart&e xcSoj=1&excTrk=1&lsite=0&ittenable=false&domain=eb ay.com&descgauge=1&cspheader=1&oneClk=1&secureDesc =0 |
I like savox servos, even the cheaper (sub 40 dollar) ones are good.
this is essentially a savox copy https://hobbyking.com/en_us/turnigy-...5kg-10sec.html and is cheap as well. |
Originally Posted by ThePanda
(Post 15073852)
this is essentially a savox copy hobbyking.com/en_us/turnigy-1258tg-digital-titanium-gear-servo-57g-13-5kg-10sec.html
and is cheap as well. ebay.co.uk/itm/Turnigy-AN13-all-purpose-Metal-Gear-Servo-14-5kg-cm-0-13s-fits-1-10-steering-HPI/322263310924?epid=2197068882&hash=item4b0863e24c:g :Ha8AAOSwmfhX20O3 |
Originally Posted by Bob Corey
(Post 15073849)
I'm on the stock right now: ebay.com/itm/HPI-1-10-Jumpshot-MT-SF-10W-HIGH-TORQUE-WATERPROOF-SERVO-Steering-Throttle/371498428709?hash=item567f082925:g:9pIAAOSwO7haAcp H
I must say that I don't quite understand the specs and what the numbers mean except from the dimentions and delay time. 4.8V or 6V is typically set by your ESC program. Setting is dependent on what voltage your receiver can handle, so if you have a manual, check there. Most radios and servos for the past 10 - 15 years have been able to run at 6V and you would see improved speed and power from your servos. The HobbyKing servos would be OK, at least you know they are a copy of name brand servos. I've heard the Power HD is OK too. |
Power HD 1501. You can get it from valuehobby.com for $12. I've used dozens of these. They are very good, decent speed, moderate torque, low budget servos. They won't perform as well as the Savox 1251MG but you could buy 4 of these for less than one Savox.
| All times are GMT -7. It is currently 07:11 PM. |
