Old 01-31-2006, 11:15 PM   #1
2001C5's Avatar
Default Help... GFX question...
I have two gfx's and they both blow fuses when I try to run my comm lathe. I have changed slave motors and get the same result. What am I doing wrong?
thanks
2001C5 is offline   Reply With Quote
Old 01-31-2006, 11:58 PM   #2
flameoutgarrett's Avatar
Send a message via MSN to flameoutgarrett
first off what amp fuze u got in it?
also how many volts u runnin it at?
Team fun-Www.rc-trim.com-Team Speedmerchant-Team Orca-Team Br00d
flameoutgarrett is offline   Reply With Quote
Old 02-01-2006, 12:07 AM   #3
2001C5's Avatar
4 volts
The single fuse is blowing not one of the two that are together. 20amp fuse
Old 02-01-2006, 12:27 AM   #4
well pretty much the only time that i blow fuses is when i put a motor on that we just wound.....that has a short in it, or when im testing endbells. shocks like to short out.
does it spool up then blow the fuse or does it not spool up at all?
do you have the same problem when you break a motor in?
trying to narrow it down
Old 02-01-2006, 12:52 AM   #5
2001C5's Avatar
I when up to 5 volts and the problem went away??
Old 02-01-2006, 01:14 AM   #6
hmm.....
about my only guess now would be that something is or was binding and when you put it up to 5 it freed up......might wanna check everything on the lathe to see how free everything is.
engine question and radio question alucard13 Nitro On-Road 12 09-12-2008 09:21 AM
Bolink TF drag car question and BL question parnelli97 Electric On-Road 2 08-20-2007 06:32 AM
This is gonna sound stupid question but I have a battery Question. Smoke21 Electric On-Road 7 04-25-2004 09:10 PM
indi charger question/3300mhz battery question TT_Vert Electric Off-Road 4 12-27-2003 12:46 PM
Nitro engine question - newbie question. BloodClod Singapore R/C Racers 6 09-11-2002 10:33 AM
