Old 01-31-2006, 09:43 PM   #1
Send a message via MSN to Colin85
Default rc12l4: diff is rough
has anyone experienced these problems, my kit is brand new, never used. everytime i spin it, it feels rough and i have a lot of grease in the balls.
i followed the instructions completely and it still feels shitty. hopefully someone else has ran into this b4
thanks, colin
Colin85 is offline   Reply With Quote
Old 01-31-2006, 10:44 PM   #2
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
Collin,
Only a couple of things could cause that. Usually it's the 1/4x3/8" bearing in the hub that is shot. Second, the balls and/or plates could have been bad or slipped causing pitting. But since you said that it is new, there is a chance that you may have initially over-tightened the diff and then backed it off. But the damage can be easily done to that hub bearing. I do have the real cure if you email me.
Brian [email protected]
Slapmaster6000 is offline   Reply With Quote
Old 02-01-2006, 01:59 AM   #3
I found that the bearings that come with the L4 are not that smooth, also you don't want lots of grease, only a tiny amount on each ball, lots of grease means you need to have it tighter to stop it slipping. Have a look on the IRS website on how to build the perfect diff.
rbecking is offline   Reply With Quote
Old 02-01-2006, 04:30 PM   #4
well i dont think its a problem with the balls in the spur. its when i tighten the nylon nut up, then i spin each side of the wheels and its rough as hell
btw where can i find this irs website?? i couldnt find it on google
Old 02-01-2006, 04:37 PM   #5
dakrat's Avatar
i think you are over tightening the nut. loosen it until its smooth and not slipping. click here for more tips
dakrat is offline   Reply With Quote
Old 02-01-2006, 04:57 PM   #6
no, ive tried loose tight medium . it will only feel good when i take the nut off and push against the thrust cone and bell washer it will feel good. nice and smooth. something is wacked???
Old 02-01-2006, 05:00 PM   #7
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Send a message via AIM to JamesArluck
www.teamirsrc.com
JamesArluck is offline   Reply With Quote
Old 02-01-2006, 05:01 PM   #8
dakrat's Avatar
is something is broke, then it would be the diff bearing. slapmaster makes great thrust bearing to replace that part
Old 02-01-2006, 05:11 PM   #9
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
You also need to break it in to seat everything. Turn the motor on while holding 1 wheel and let it spin for about 30 seconds. Then grab the other wheel and do the same. this will help a lot I think.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 02-01-2006, 05:32 PM   #10
the bearings are fine, their brand new!
ill try gixxer's idea
Old 02-01-2006, 05:39 PM   #11
Make sure there are no burs or dirt on the spur where the rings ride and diff balls are located. In the past I have had issues with spurs just not working correctly, and then put on a new one or another brand, which cured the problem. In addition, notice if rings are groove if not new.
Fast Faisal
Fast Faisal is offline   Reply With Quote
Old 02-01-2006, 05:52 PM   #12
I had the same problem but then i did what gixxer said
and now its sweet as
Simon A is offline   Reply With Quote
Old 02-01-2006, 06:05 PM   #13
My diff always feels like crap for some reason when I put it back together but as soon as I break it in, it feels fine.
Joe Cude
Old 02-01-2006, 06:27 PM   #14
Switch Blade's Avatar
Send a message via AIM to Switch Blade
I will second that. I hold each tire for a minute(i thin per crc's web site) though.
College
Switch Blade is offline   Reply With Quote
Old 02-01-2006, 10:21 PM   #15
my brothers is much smoother, but ill try holding it while giving it gas
JP2 Pipe, a little rough but cheap! t4ftracer R/C Items: For Sale/Trade 1 11-05-2007 09:49 PM
best 4wd for rough track ollie2314 Electric Off-Road 16 10-04-2007 05:57 PM
What weight oil in XXX-4 on rough track? yellowpasta2000 Electric Off-Road 10 03-23-2007 07:58 AM
rough runnings beetlebz Electric Off-Road 3 09-28-2004 01:07 PM
Rough rider gtrcman64 R/C Items: For Sale/Trade 1 08-04-2003 06:40 AM
