PXtoys NO.9300 1/18 not working
Hi guys,
I just bought this car and after one use it does not working. I changed servo but still not working. I attached an video, hope you can help with an advice. Maybe the battery is dead?
photos.app.goo.gl/A0nbHKB2EQYc3tVn1
I thought the servo is the problem. Also, today I tried with other motor and same problem. It starts for 2 seconds and then is not working anymore. I made an video to see the exact problem: youtu.be/2vp8NDSRn6s
I think the esc is correct connected to channel.
Thanks for your reply!
Could be a bad battery. The ESC may be going into a voltage protection mode. At first, the voltage might be high enough, but under load, the voltage drops. If you have a different battery, try that to see if there is a different behavior. If not that, then it is likely a problem with the ESC. Do you have access to another ESC that you can test with?
I tried with another batterry but still not working. This is the ESC module?
banggood.com/Pxtoys-118-RC-Truck-HJ209131-Receiving-Plate-PX9300-28-RC-Car-Spare-Parts-p-1064664.html
I''m thinking to buy a new one but I'm not sure that it will work.
