Slipper clutch question
So today i changed the spur gear on my tamiya dn01 because the 77t one i had showed alot of wear by a group of 10-15 teeth. When i put a 72t spur on with the slipper clutch all seemed fine. Testing the car on my stand worked and seemed fine, but when i placed it on the ground it slipped so bad to almost no acceleration. I loosened, tightened back and forth both the slipper and ball diff. I even reinstalled the spur and slipper 3 times. All with the same problem no acceleration once the tires are on the ground. Any help as to why?
I think now it was the slipper pads that might be the issue. I had no extras so they are coming tomorrow. I think when i flipped the car it caused the spur and pinion mesh to jam and caused the spur to get chewed. It possibly ruined the slipper pads because one showed alot of wear
