Best motor cooling fan
#31
Depends upon the placement of the fan. If you have a fan mounted on the chassis and its placed behind the motor its more efficient at removing the heat sucking. Consider this, if there was no fan, airflow, (what little there is) moves from front to back as the car moves forward. So blowing from back to front will have less effect.
#32
But for it to be effective, the rest of the body would need to be pretty well sealed up and only have cutouts directing the air toward the motor. It is easier and more efficient to just have the fan blowing directly on the motor. It could help though to have two fans, one going on the motor and one at the back pulling the warm air out.
#33
You would need a dedicated intake and exhaust for it to be effective, with the rest of the body sealed or else you'd never get enough airflow over the motor itself to make a huge difference, you'd just be extracting the warmer air lowering ambient temps inside of the body which is still good. But that might only get you half the cooling performance compared to the fan blowing directly on the motor.
#34
If your using a fan blowing against the natural airflow under the shell it wont be as efficient as it would be pulling air over the motor with the natural airflow. Its free airflow, use it. Dont fight it.
#36
Thanks for all the replies.
I had bought a fan mount for the XB2 that vertically mounts using the motor waterfall. I will have to cut an opening in the body. That being said, I am still partial to thinking of pulling heat away due to the location of the fan/motor, and since heat rises I'd hate to be circulating heat within the body by pushing in air and not having it go anywhere.
I will try it both ways and see what is best but really appreciate all the reccos.
#37
#40
wtf fans are normally 6v to 8.4v..never seen 1 rated for 6 cells.
#42
#44
Protip: you can increase the performance of dual fan setups by putting a lexan sheet between them, avoiding them slowing each other down by competing for the same air.
It's standard practice in HVAC and I tested it with pc fans (which report their rotation speed) and the increase was close to 20%
#45
