Motor Too Hot
Motor Too Hot
I have an Eb48.4 and I'm running it on a Tekin 3000kv Pro 4 HD with 3s 6500mah 75c Battery
It is getting insanely hot like it came off at 240 yesterday after practice. The gearing was 15/44.
It still comes off 180-190 after 6 mins
What is HAPPENING
Is it a gearing issue?
Is it a problem because of the 3000kv on 3s?
Please help
What is HAPPENING
Please help
What is HAPPENING
Please help
What is HAPPENING
Please help
1: can your car roll unhindered when the motor is removed? There should be zero binding.
2. Are you wide open throttle most of the time?
3: why did you chose a short course motor for a full weight e-buggy?
Hopefully someone has a better solution though.
It might do better on a smaller indoor track though. That's where I run my eb48sl with a short course motor and granted things still get hot, they don't go over 160 after beating the heck out of it.
That combo in a full weight e-buggy isn't going to work well. Plus with those motors will go bad quickly after you get them hot. The heat damages the magnets which makes it run hotter, which does more damage etc. It will give up soon. Especially after it desoldered.
Most likely it's just too much weight and drivetrain for that 3000kv.
Are you still running 3s or did you bump to 4s?
