TEAM ASSOCIATED DB8 >
TEAM ASSOCIATED DB8
Like Tree25Likes
TEAM ASSOCIATED DB8
Old 06-13-2018, 10:39 PM
  #136
Dieselboy420's Avatar
Default Noobie/New Member
Hi guys. I'm new to this website and new to the whole electric RC world. Coming from gas RCs I need all the help I can get with this monster. I just picked my DB8 a few days ago and right way started looking for tires and some mods. I have a question for you guys. I was looking at some videos and I found out I can squeeze some more MPH on this baby if I were to the pinion. So stock is 15T I believe. So if I were to put a 20T, pinion, would that make a big difference? and of coarse I would be running a 4s Battery.
-Thanks
Dieselboy420 is offline
Old 06-13-2018, 10:40 PM
  #137
I just picked those up today. Badass tires
Old 06-14-2018, 04:49 AM
  #138
Well, you would go faster with the bigger pinion, yes. But keep in mind that that comes with an increase in load and thus heat on the electronics, so you need to watch your temps so you don't overheat.
tvih is offline
Old 06-14-2018, 08:02 AM
  #139
Good point and thank you.
Old 06-16-2018, 12:19 AM
  #140
ericmyson's Avatar
Default Hyrax on the stock db8 wheels
Forced fit the 2.2 hyrax over the stock 2.2/3.0 wheels. I was shocked with the outcome.. worked very well.. it held up on two runs on 6s batteries..
ericmyson is offline
Old 06-16-2018, 12:23 AM
  #141
ericmyson's Avatar
Default 2.2 Hyrax on 2.2/3.0 wheels
I stretched the inner hyrax tire bead lip over the 3.0 bead lip of the wheel and carefully glued them on lol
Old 06-16-2018, 12:29 AM
  #142
ericmyson's Avatar
Default Hyrax over 2.2/3.0 wheel
Side note: as u can see in the pic, the inner side of the hyrax was stretched and pushed in and past the lip bead of the 3.0 side of the wheel.
(did that make sense?) 😂
Applied glue very carefully.. 😂
These
tires make a night and day difference from the stock tires..
Old 06-16-2018, 12:39 AM
  #143
ericmyson's Avatar
Default Hyrax 2.2 tires in 2.2/3.0 wheels
Btw, the hyrax 2.2 tire and 2.2/3.0 wheel combo is on my brushless MGT that is in the pic. I just mounted the nomad cage on the MGT
i have a nomad db8 but its waiTing for some hop up parts. This hyrax wheel combo do fit on nomad. I will post pics as soon as the build is done
Old 06-16-2018, 04:56 AM
  #144
chainsaw10's Avatar
Lookin good. But if you used some body scissors and trimmed a little bit of rubber off the inner tire it would fit right into the molded groove on the wheel. It’ll glue up easier that way....and better contact to glue
Dave_S likes this.
chainsaw10 is offline
Old 06-16-2018, 09:37 AM
  #145
ericmyson's Avatar
ill try that on my next set lol
Dave_S likes this.
Old 06-18-2018, 03:34 PM
  #146
Heres another tire option. 2.8 proline badlands stretched over 1/8 buggy wheels.
A little shorter but should work well. I havent ran it yet with the new tires.
Dave_S likes this.
twisted is offline
Old 06-20-2018, 10:59 AM
  #147
new tires work pretty good but my servo stripped and i lost a arm mount bushing.
twisted is offline
Old 07-10-2018, 07:01 PM
  #148
can you use a 6S batt. on a stock nomad? another question. how did you get yours soo high???
Old 07-10-2018, 11:19 PM
  #149
ericmyson's Avatar
Old 07-10-2018, 11:34 PM
  #150
ericmyson's Avatar
its a mgt brushless conversion with a nomad body cage. I use a hobby wing xr8 plus esc
[/left]
