Turnigy Graphene Batteries
Ive seen a lot of articles about these when they first came out but really no new information since. Any one have any experience with these batteries and what has it been like?
They are excellent! Most powerful 4.2v battery on the market. I don't think you'll find much feedback in this section, most racers use stuff like SMC hard cases. If you want to read the largest battery testing thread on the Internet, go to this link https://www.rcgroups.com/forums/show...st-Comparisons
Turnigy Graphene 2S shorty were out last year, 6-7++ months before any others released. reason you did not see them much, these packs were at the time only available thru hobbykings HK warehouse and shipping, hazmat handling etc fees were on the order of $45+ added to each pack. these packs were able to go 4.35+ per cell although they weren't advertised. racers that had them swore by them as being insanely good
prior to graphene formal announcement from various companies....protek had three regular 2S lipo packs of different MAH, one of those three, but not the highest was 4.35 per cell capable, also not advertised, but was well known among 17.5 class racers. LRP had packs not labeled as graphene, but where labeled as "outlaw" that could be also charged at 4.35 per cell. |
I have three if the 4s 5000 mah turnigy Graphine lipos for my 1/8 e buggy. They are nothing short of brilliant. Huge power on tap and longer run times than many batteries rated at a higher capacity.
I did have one pull off its internal tabs after a fairly massive crash, but it was clearly user error on my part. Not had it happen since, despite repeated abuse since. |
I was seriously looking into these but then realized how heavy they are? Like 2x the weight? I assume its because they put cells in parallel, which almost seems like cheating imo. Anyone know if this is inherent of graphene batteries?
2s pack built internally in a parallel config would be same as a 1s pack 3.7v
graphene packs are still basicly LIPO packs, they are not heavier, believe hobbyking has pack weight wrong at 505g. lipo and graphene lipos are pretty close in weights and vary by manufacturer, nothing drastic Gens Ace 2s Shorty LiPo Battery Pack 60C w/4mm Bullet (7.4V/5000mAh) 213g Reedy Zappers 2S Hard Case LiPo 70C Shorty Battery (7.6V/5800mAh) 223g Team Orion 2S Carbon Pro Ultra 110C LiPo Shorty Battery (7.4V/5000mAh) 217g LRP Light Stock Spec Shorty P5-HV Graphene 2S LiPo 60C Battery (7.6V/4600mAh) 206g Team Trinity Titanium Shorty 2S 50C Hardcase LiPo Battery (7.4V/4500mAh) 204g ProTek RC 2S 100C Silicon Graphene HV Shorty LiPo Battery (7.6V/4900mAh) 203g Fantom Racing Competition Series Shorty 2S LiPo 70C Battery (7.4V/4600mAh) 216g Fantom Racing Competition Series Shorty 2S LiPo 70C Battery (7.4V/4600mAh) 216g |
I started sharing my experience with Graphene on post#123 here:
Anything better than LiPo on the horizon? - Electric Motors, ESCs, batteries, etc. @ URC Forums
Originally Posted by Bill DeLong 10-FEB-2016
Not exactly what I was expecting performance wise, but to be fair this was the very first cycle, I'm going to try and loan the pack to another racer to help me test it this weekend and see what he thinks. Hopefully a hand full of cycles will "wake" up the pack and it might start to perform a little better. I threw in a couple older tests without temp readings, but I'm going to start measuring temps at the end of each cycle to compare efficiency that way... I noticed that Vant pack came off at 115° where the Graphene pack was only 105° which is 115/105 = 10% cooler supporting the claims in the specs. I'll certainly do another re-test next week and see how things go. In 4WD SCT, pack performance isn't nearly as important as pack longevity, if the Graphene pack lasts longer than 6 months without loss of capacity, then that in itself is a huge win!
https://c2.staticflickr.com/2/1571/2...6ed9ee30_b.jpg
Originally Posted by Bill DeLong 17-FEB-2016
I ran 6 cycles through my 2S-6.6Ah graphene pack this past weekend in my 4WD SC and couldn't tell any difference in performance when compared to other 75C and 90C packs that I've ran in the past. Car cleared all the jumps with equal consistency and left me very happy with it. A local racer had an iCharger and he tested the IR during the charge cycle at various times and the lowest reading I ever saw was 1.5IR on one of the cells, but never saw both cells get that reading, at least one cell consistently read 3.5IR or higher with most of the time the IR readings were averaging 3.0IR
using his charger we charged the pack at 50A = 7.6C and the pack didn't break a sweat, it came off the charger at 105° No signs of swelling after heavy abuse running the pack down to LVC each time, I'm going to try and run another discharge graph later this week, although the pack hasn't seen a full 12 cycles yet.
Originally Posted by Bill DeLong 4-JUN-2017
So after 16 months of racing with my first Graphene pack, the time has finally come for me to retire it... technically the pack can still get me through a main without any issue, however I ran into an issue with the pack last race day where the negative post would de-solder itself after 3 mins of open practice and re-soldered 2 times before investigating further. In a pinch I had traced the issue to a bad 5mm to 4mm bullet adapter that was tarnished and wasn't getting a good connection. I soldered on a fresh 5mm bullet and was able to get another full race day on the pack without any other issues.
Still a very competitive pack, my 4WD SC was turning lap times comparable with most 1/8 buggies at my local club: Thornhill Racing Circuit :: Thornhill 5/27 Summer Series #1 :: 4x4 Shortcourse Double A-Main Results :: LiveRC The only reason why I've decided to retire the pack is because it started swelling after the worn connector allowed too much heat to de-solder the bullet... I probably could've got a lot more life out of the pack if I hadn't used the 5mm to 4mm bullet adapter ( or replaced them sooner) https://c1.staticflickr.com/5/4259/3...3d4a2e59_c.jpg |
Turning graphene or protek LIhV graphene? Anyone compare both?
the turnigy graphene pack was never sold or touted as a chargeable to 4.35v per cell pack either were other packs that had this capability 6-7++ months ago other than the LRP Outlaw packs. so unless you charged at 4.35, you would not get results that a graphene could produce. even to this day, there is no mention that this pack is 4.35 per cell capable. also if the pack was not charged at the higher rate the pack probably did not reach it's full MAH capacity to perform vs the LIPOs it was tested against
https://hobbyking.com/en_us/graphene...connector.html last year when US based sellers released their LIHVs we had some oval racers do testing: charging, and graphing discharges. they recommened, if you go to a track that enforces 4.20 per cell bring LIPOs, allows 4.35 to have LIHVs. this is what they found in a nutshell charging LIHVs (graphene-LIPOs) at 4.20 per cell, then discharging they did not outperform LIPOs (standard-LIPOs) when graphed out. some they did precycling, others none. this was done at various amps 10 to 70. LIPOs were better. charging LIHVs at 4.35 per cell, everything changed drasticlly, and the LIHVs outperformed LIPOs in all tests and performed as sellers advertise. even at 10 amps, charged at 4.35 per cell the LIHV outperformed LIPOs. sellers advertising and statements on LIHV, this is were i believe there may be a issue and confusion. will use some examples and highlights, hopefully brand loyalists won't flame. on this pack in the overview, ProTek RC 2S 100C Silicon Graphene HV Shorty LiPo Battery (7.6V/6100mAh) it states: "While these batteries are technically LiHV cells, they can still be charged with a standard LiPo charger. The overall voltage and capacity will be slightly less than if charged to LiHV specs, but the performance will be better than a standard LiPo thanks to the reduced weight and low internal resistance." the pack is not a 6100mah pack unless charged at the higher rate. LRP Stock Spec Shorty P5-HV Graphene 2S LiPo 60C Battery (7.6V/6000mAh) does not state to have a difference, only saying they are "100% compatible for 8.40V (2S)" and "Charge with your standard LiPo charger for 8.4V or with LiHV charger for 8.7V". LRP does not makes claims of equal or better discharge curves, run times, etc Reedy Zappers HV 2S Hard Case LiPo 100C Shorty Battery (7.6V/4800mAh) overview: Even when the typical 8.4V (4.2V/cell) charging limit is enforced, the battery still offers a significant advantage thanks to a flatter discharge curve -- which results in more voltage deeper into the race. For those who race where approved batteries are required, 7.4V are available and feature the same discharge curve characteristics as the 7.6V versions. Fantom Racing 5500mAh 7.6v 2S HV Pro Racing shorty LiPo in their overview recently on New Fantom Racing 5500mAh 7.6v 2S HV Pro Racing shorty LiPo :: LiveRC.com - R/C Car News, Pictures, Videos, and More were some interesting tidbits: "These HV batteries are only an advantage if you are allowed to fully charge them to 8.7 volts." and "IMPORTANT: This battery requires a charger that is capable of charging up to 8.7 volts (4.35 volts per cell) to obtain the maximum performance out of it." pretty much along the lines of what midwest oval racers came up with last year. Fantom even recommends you go with a standard LIPO if you can't charge to 4.35. things that makes you go...hmmmmmmmm:nod: |
So just curious about these batteries, and I haven't been able to find anything specific online.
To charge these batteries need a special charger to be charged to their maximum 4.35 per cell? Or will simply charging them on a lipo charger in lipo mode get them there? thanks |
I would think most chargers have a adjustment for that
Originally Posted by Pinkz
(Post 14954451)
graphene packs are still basicly LIPO packs, they are not heavier, believe hobbyking has pack weight wrong at 505g. lipo and graphene lipos are pretty close in weights and vary by manufacturer, nothing drastic Gens Ace 2s Shorty LiPo Battery Pack 60C w/4mm Bullet (7.4V/5000mAh) 213g Reedy Zappers 2S Hard Case LiPo 70C Shorty Battery (7.6V/5800mAh) 223g Team Orion 2S Carbon Pro Ultra 110C LiPo Shorty Battery (7.4V/5000mAh) 217g LRP Light Stock Spec Shorty P5-HV Graphene 2S LiPo 60C Battery (7.6V/4600mAh) 206g Team Trinity Titanium Shorty 2S 50C Hardcase LiPo Battery (7.4V/4500mAh) 204g ProTek RC 2S 100C Silicon Graphene HV Shorty LiPo Battery (7.6V/4900mAh) 203g Fantom Racing Competition Series Shorty 2S LiPo 70C Battery (7.4V/4600mAh) 216g Fantom Racing Competition Series Shorty 2S LiPo 70C Battery (7.4V/4600mAh) 216g https://hobbyking.com/en_us/graphene...connector.html True Spec Premium 7.4V 7200mAh 131 Amps/90C 5mm Inboard |
anyone tried in a team C 1/8th scale buggy?
Specs: graphene are Same weight as the SMC batteries, smc are 205
Capacity: 4600mAh Voltage: 2S2P / 2 Cell / 7.4V Discharge: 90C Constant Weight: 206g (including wire, plug & case) Dimensions: 96x47x26mm Balance Plug: JST-XH Discharge Plug: 5.00mm (in case) |
Originally Posted by Mirkinator
(Post 14954745)
Says right on their site 695grms for the 5600mah battery. Compared to a SMC 7200 with almost %20 more runtime at 310grms. Have you weighed one yourself or anyone? Dont see why they would put it wrong when it has a huge effect on performance...
