Buggy Diffing out when braking?  Skidding out >
Old 06-02-2017, 03:15 PM
JAE
Trader Rating: 30 (100%+)
Default Buggy Diffing out when braking? Skidding out
Not technically diffing out but same effect while braking... 2wd buggy skids out a bit sideways while braking in a straight line. Have two identical buggies set up basically the same way. One does it, the other doesn't. It brakes in a straight line like I have the wheels turned a little bit. Anyone know where to start?
JAE is offline
Old 06-02-2017, 03:41 PM
A rear roll center that is much higher than the front will typically result in the same thing happening.
fredswain is offline
Old 06-02-2017, 03:56 PM
just turn down the brake so it doesn't lock up anymore?
nicholasxuu is offline
Old 06-05-2017, 12:59 AM
JAE
Buggy will slide a bit when not even braking that hard... strange and the roll centers are pretty even (1mm front tower 1mm front hub as 2/2 for rear as well) ...
JAE is offline
Old 06-05-2017, 02:15 AM
ray_munday's Avatar
First thing is make sure your shocks are all set to equal preload, droop and springs are set evenly. If possible put it on a set of corner scales and try to get the rear weights even. Make sure the chassis isn't twisted. Also make sure you have the left/right balance as close to equal as possible.
Other options:
- check rear wheel bearings and diff output bearings for any tight / seized parts
- make sure the rear toe is equal left/right
- make sure the wheelbase is equal left/right
Hope this helps.
Ray
ray_munday is offline
Old 06-05-2017, 08:29 AM
JAE
Checked most of that but not diff bearing or chassis tweak. Thanks!
Other options:
Hope this helps.
Ray
JAE is offline
Old 06-05-2017, 08:48 AM
Sometimes a hex adapter can bind up, even if the bearings are ok.
071crazy is offline
